What if you use rb25det injectors and fuel rail on a rb20det?skillzilla wrote:An RB25 ECU will run an RB20, just not very well.
Ok. It was just a thought. Perhaps I should talk to you about a rom tuneCarl H wrote:dont run a rb25 ecu on a rb20, its poo poo.
Seeing as how the RB25DET uses sidefeeds and the RB20DET uses topfeeds that would be difficult.Vkoslak wrote:
I have an idea, but it may be a bad one.
the same EXACT situation happened at a local shop here, turned out to be the engine importers screw up. Supposedly the shop didnt know the differences and just went by what they said. Still, youre doing an RB swap you should be able to tell what motor it is...themadscientist wrote:Just get bigger topfeeds silly I hope he gets some resolution of this situation, either some money back or complete refund. This sort of stuff deserves an old-fashioned beatdown.
I think some boltholes wouldn't line up Common sense is not common these days unfortunately. I suggest we drop the "common" from "common sense" and replace it with "good". "good sense" implys the idea without the false promise of widespread possesion of it.BoostsFed wrote: what if i put a 2jz valve cover on and sell you the car for $30k????? where's all the common-sence, geez!
Good idea, I'm with you on this one.themadscientist wrote:I think some boltholes wouldn't line up Common sense is not common these days unfortunately. I suggest we drop the "common" from "common sense" and replace it with "good". "good sense" implys the idea without the false promise of widespread possesion of it.
