The original pic on the first post showing several setups is dead.
So i updated my setup and ditched the breather filter and ran that line from the exhaust side vc to the intake tube before the turbo. Im getting a lot of oil burn now and going to finally put in a catch can but undecided on what i should do. Im planning on running the the catch can inbetween the hose to the intake tube. Also undecided if i want to eliminate the pcv and plug the intake port or leave it and throw in a new pcv valve (anyone know us equivalent part #?)
Also debating on getting rid of the inlet to the intake but unsure if thats a good idea. Reason being if oil passes through i dont want it going back into the turbo. Or should i be good with the catch can?
Also im concerned under high boost my fitting on the exhaust side vc pops out. I was always wondering why the vc ports are so loose, what do you guys do to fix this? i see the AN fitting option but id like to avoid that to save some money not having to get the lines and fittings to work with those. Please help, all input appreciated...need to addess these issues asap so i can get in my final tune session
