How to Seafoam your engine the right way. Complete DIY
WDRacing
dostrander wrote:I haven't tried Seafoam before, but I'd line to give it a try. I'm curios about something tho... In the OP write up on how to do it, it's suggested to use the brake booster line. Where the boosters line enters the plenum is on the far right side (rear of engine (at least on my VQ35DE )). Can you get a reasonably even distribution across all cylinders from there? Wouldn't it be better to use the canister purge valve entrance which is on center just behind the throttle body? (again, at least on my VQ35DE). Would appreciate any opinions.
The old method is semi obsolete with the new Sea Foam Spray. You just use the hose that comes with the can. It has a hook on the end that goes over the throttle body. Similar to a WD40 tube, but with a hook to facilitate use while having everything connected as it should be while running.
Just remove the intake pipe from the throttle body, hook the tube onto the throttle body itself and then reconnect the air intake pipe. Start, spray, wait, start and enjoy the smoke.
darylzero
Car: 2026 Toyota 4Runner Sport Premium
Previous-Nissan Rogue 2009 SL AWD Premium Pkg.
Before and After results using Seafoam
[youtube]http://www.youtube.com/watch?v=u6UeJXkzDW8[/youtube]
nissangirl74
Summer is almost here! Make sure to Seafoam your engine before you head out on that road trip.
