How to make Wheels wider ?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Hookm36
Car: 2004 G35 coupe
Question....My rear wheels are not as wide as I would like them to be. Now they are 275/35/19 and the rim is 10inches wide, so thats good, but it doesn't fit on the car as wide as I would like. Ok looking at the rear wheel I want the top part of the tire to be even with the top part of the fender, and the bottom of the tire to be sticking out a little. Right now the entire wheel is all inside the fender. I will submit a picture after I get off work......any suggestions ?
Hookm36
Car: 2004 G35 coupe
You can run a 10-15mm spacer on the rear of the G Coupe with no adverse effects.
I recommend a bolt-on hubcentric unit such as the ones made by Ichiba, which you can get throuh our sponsor Intense.
Hookm36
Car: 2004 G35 coupe
what are the possible effects ? Would I need an allignment afterwords ?
Not so great for your wheel bearings to go too radical, but 10-15mm is no biggie.
I ran 25mm on all 4 corners on my G for about 6 months and it looked great.
No need for alignment, if yours is set to specs. All you're doing is pushing the wheels out away from the hub.
Hookm36
Car: 2004 G35 coupe
Thanks for the help.......cant find the sponsor ?
also where can I get a z-tube for 50 bucks ? and will connecting it to a stock air box w/ k&N filter make any difference in sound or performance ?
joe603
Car: 2014 Durango R/T
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
BUT your signature says "Get it right the first time".
What happened HOOKM??
FamilyZ
Car: 350 gt
I know what will fix ur problem. Lower ur car, that'll show you how wide your wheels really are. I recommend eibach pro kit springs. They ride better than stock. My wheels are 18x10" wide in the back.
Hookm36
Car: 2004 G35 coupe
cali - I knew someone would say something.....truth is, I never thought it wouldnt be wide enough w/ a 10 inch wide rim !
Thanks Joe........although I cant find the bolt-on hubcentric unit frim Ichiba ? What kind of deal can I get for 2 Pop-charger z-tube combo's ? e-mail [email protected]
A good friend of mine just bought a 04 G35, and also happens to be buying a house down the street from me................look forward to some nice pics showcasing both G's....
Modified by Hookm36 at 8:17 PM 8/14/2007
joe603
FamilyZ,
Nice garage floor!!
Hookm36,
Call EverythingG35...they might be able to cut you a deal.
Here's the spacer link:
http://www.ichibausa.com/
or
zerothread/177674
FamilyZ
Car: 350 gt
Thanks, I painted it myself
Hookm36
Car: 2004 G35 coupe
dont really want to lower car, as i am an every day driver, plus my wife might drive once a week, and dont want to get pissed at her for scratching the front bumper...
I saw that the 25mm spacer will push the wheel almost an inch........im wondering if I will even be able to see a significant difference ? it doesnt seem like I will, anyone have any insight to this ? for the money, id rather have a Pop charger............
An inch wider stance all the way around makes a HUGE difference, it's VERY obvious.
Hookm36
Car: 2004 G35 coupe
well, just went out and measured the difference from the face of the tire to the inner wall of the fender and............there is no difference !! so my question now is : will the rear tire ever hit the fender ? It looks as though if i add a 20mm spacer that would put the tire dir3ectly under the fender and I have 4 people riding in the car and hit a bump on the highway, will the tire rub the fender ?
Quite possibly, yes.
A fender roll to get a flush fitment might be in order.
HOWEVER, you're overlooking the effects of increased camber upon suspension compression.
As your rear drops, the top of the wheel moves IN towards the center... It "cambers in" and tucks into the wheelwell.
Therefore, sometimes when a car looks like the tires will hit the wheelwell, in reality, they wont, because of the arc the wheel travels in.
Hookm36
Car: 2004 G35 coupe
Very true, didnt think about the wheel path. Do you have any advice on how to get 2 sets of JWT pop charger/Ztube combo for the best price ?
Focusedintntions
Car: 07 Infiniti G35 Coupe 6mt
I would venture to say the cheapest and easiest solution would be just some small 15mm spacers....
The expensive solution would be find a new set of rims that have the offset you're looking for.
G_whizz
Car: 2010 G37 Coupe Sport
I'm actually enjoying watching this thread... it amazes me at some of the stuff you guys know.. just a wealth of knowledge on here... these are ALL questions and concerns that I was thinking about as well if I wanted to go this route
NICO...sooooooo ROX
Hookm36
Car: 2004 G35 coupe
anyone wanna buy my rims !! haha
Hookm36
Car: 2004 G35 coupe
Just called EverythingG35.....really really rude ! spoke w/ Mike, I asked him if there was a discount since I am a nico member, and all he said was "NO!".....so I asked him ok what if I purchase 2 combo's, (charger/z-tube)he said "there is still no discount" 195.00 a piece !.....what an ***........i hate to say it, but I dont wanna purchase anything from them ! really really bad experience...
sucks too, cause I was pretty excited about purchasing today
Ouch, not cool.
Although, I think that IS the discounted price....
Seems you might want to get a little more focused on what you want to do with the car first... It's a lot easier than just throwing parts at it. Your wheel / tire combo is fine, and will look great with some 10mm spacers on all 4 corners....
FamilyZ
Car: 350 gt
Good customer service is very rare now a days Poor guy doesn't even know who writes his checks. Obviously (we do) the consumer.
WESIDE
Car: 2006 g35 coupe
Try talking to Darren at Intense Motorsports. I have purchased tons of stuff from these guys on the internet and they have been the nicest people to do business with that I have come across. Give a call and I am sure they can do something for you.http://www.i-m-racing.com/index.html
joe603
Hookm36 wrote:Just called EverythingG35.....really really rude ! spoke w/ Mike, I asked him if there was a discount since I am a nico member, and all he said was "NO!".....so I asked him ok what if I purchase 2 combo's, (charger/z-tube)he said "there is still no discount" 195.00 a piece !.....what an ***........i hate to say it, but I dont wanna purchase anything from them ! really really bad experience...
Ask for Justin or Joe...I've also had problems with Mike.
Hookm36
Car: 2004 G35 coupe
Yep......called back, spoke w/ Joe, he sold me the JWT pop charger and z-tube shipped to my door for 200.00 ! purchased 2 of them.
thanks guys
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
The width of your rims is immaterial if the offset is too positive. With 10" rims you probably needed an offset close to 0
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Sentientbydesign wrote:The width of your rims is immaterial if the offset is too positive. With 10" rims you probably needed an offset close to 0
Not quite..
a +20 offset is considered flush on the G35 and a +15ish is "Agressive"
My wheels are 9.5 inches wide +20 and they are perfect!
Sentientbydesign
96 I30 - Sold
Kenrik wrote:
Not quite..
I tried emailing you about your rims, but I never got a reply. Would you have gone with 19" rims if you did it over again? I want 18s for weight and tire selection, but most that I've seen on the coupes look pathetic. Yours look oddly good and I can't figure out why.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
I don't know how different the Z is but....
A little dirty but, 18x10 +10, 275/45/18 Falken's FWIW....
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
