_____ICHIBA USA Aluminum Hubcentric Wheel Spacer All Sizes Available
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
www.ichibausa.com
ICHIBA USA Aluminum Hubcentric Wheel Spacers
http://www.ichibausa.com
240SX 89-94 S13
5MM Aluminum Wheel Spacer $59
10MM Aluminum Wheel Spacer $99 ***New***
15MM Aluminum Wheel Spacer $99
20MM Aluminum Wheel Spacer $109 ***New***
25MM Aluminum Wheel Spacer $129 (Out Of Stock)
Nissan: 240SX S14, 350Z, 300ZX, Maxima, AltimaInfiniti: FX35, FX45, M35, G35, M45
Again, they are all in stock & ready to ship!
Description:
Wheel Spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
S13 240SX 89-94:Bolt Pattern: 4/114.3Center Bore: 66.2Thread: 12x1.25Longer Studs Included
Nissan: 240SX S14, 350Z, 300ZX, Maxima, AltimaInfiniti: FX35, FX45, M35, G35, M45Bolt Pattern: 5/114.3Center Bore: 66.2Thread: 12x1.25Longer Studs Included
Modified by www.ichibausa.com at 4:37 PM 12/28/2006
www.ichibausa.com
Before & After
BlackFlag_s13
You do custom spacer sizes?
www.ichibausa.com
BlackFlag_s13 wrote:You do custom spacer sizes?
Sorry we don't custom spacer sizes.
veilside180sx
Do you do 4x100 spacers for Sentra's?
www.ichibausa.com
veilside180sx wrote:Do you do 4x100 spacers for Sentra's?
Would you please let me know year and model of your sentra?
veilside180sx
1998. They are the same from 91-99 with a 59mm hub. Following which they switched to 4x114.3 for the lug pattern.
Modified by veilside180sx at 6:01 PM 6/22/2006
matt147
Any word on the Sentra fitment?
www.ichibausa.com
paNX2K&SE-R wrote:Any word on the Sentra fitment?
Sorry we don't have that application yet.
www.ichibausa.com
How To Measure?
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need.
5MM = 0.197 INCH15MM = 0.590 INCH20MM = 0.787 INCH25MM = 0.983 INCH
94_240sx
Car: 94_240SX
10mm???? I need 4x114.3 10mm spacers. You don't make them? I'm planning to use longer studs though.
94_240sx
Car: 94_240SX
94_240sx wrote:10mm???? I need 4x114.3 10mm spacers. You don't make them? I'm planning to use longer studs though.
Just called them and found out 10mm will be available in October.
www.ichibausa.com
Sorry we don't have any 10MM yet.
Blown240sx
Car: 1996 240sx
what if i have staggered wheels...front are 18x8.5 and rear 18x 9.5 and all 4 are 35mm offset...with the 25mm spacer give it enough clearence for suspention...i know i would have to roll the fenders but i want to know with a + 10 offset give enough clearence and look good
Blown240sx
Car: 1996 240sx
also is this price PER spacer???!???
www.ichibausa.com
Blown240sx wrote:also is this price PER spacer???!???
for sure it's for a pair (2pcs)
efrain240sx
Car: 1992 nissan 240sx HB
does the price include shipping or is that extra. thanks
www.ichibausa.com
efrain240sx wrote:does the price include shipping or is that extra. thanks
The shipping is extra, it's about $10.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
do you have s14 4 lug spacers?
Dori Dori
Car: Cars of course
On an S14, are they different for the front and rear because on an S14 the studs are not the same from front to back?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
hey Dori,are you still in contact with that local shop that imports HLSD's? i was just doing some searching and found an old post of yours about them. shoot me an email! (in my profile)sorry bout the threadjack, i thought it would be best to post this in your most recent post. and it's a bump for the question you asked
chattanoogarebel
Car: 240sx
Excuse me for a stupid question, but I have a 1992 hatch with 215/45 17's on the back with spec-v rims and I want to put them on the front also,but the KYB AGX and Sportline springs are dangerously close to that size tire , would 10 mm fix that?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
i'd just put them on to find out, but i don't know for sure. I bet the wheel, tire, and suspension forum could help ya much better than the advertiser forum
edit: sorry i though this was the advertiser forum
94_240sx
Car: 94_240SX
Any update on 10mm spacers?
www.ichibausa.com
mmm240 wrote:i'd just put them on to find out, but i don't know for sure. I bet the wheel, tire, and suspension forum could help ya much better than the advertiser forum
I will talk with Greg (admin). Thanks for your message.
www.ichibausa.com
New Update:
S135MM: Instock15MM: Instock25MM: Instock
S145MM: Instock15MM: Instock20MM: Out Of Stock (Coming NOV 2006)25MM: Out Of Stock (Coming NOV 2006)
S13 10MM: New Item In DevelopmentS13 20MM: New Item (Coming NOV 2006)S14 10MM: New Item (Coming NOV 2006)
smokey240sx
i'm also intrested in 10mm spacers
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
smokey240sx wrote:i'm also intrested in 10mm spacers
ditto
also, why are 16 studs shown in the first pic? same w/ other pics of 5mm and 15mm spacers
edit: i checked out your website and it says 8 longer studs included. guess the pic is a mistake.
www.ichibausa.com
The photo shown 16 studs just for better photo style design.
S13 package have 8 studs & S14 package have 10 studs.
www.ichibausa.com
10MM Sample just installed, everything is perfect!
The shipment is coming very soon.
Return to “Advertisers' Marketplace!”
