i couldn't find these..The_Chosen_One wrote:These are the oil fittings you need. If your non Ball Bearing or if you are and the turbo has the built in restrictor. This is a open fitting that is a 7/16 Inverted Flare to -4ANThis fitting goes on the Oil Block where it turns 90*. This is a M12x1.0 to -4AN fitting. This connects to the turbo oil line and connects to the above fittings.
The gold fittings can be found here at ATPdat_twinkie wrote:i couldn't find these..
I aim to please my sex kittenr34 gtr wrote:you are quite the sexy beast. quality writeup!
The_Chosen_One wrote:some thing like this?
Quantity Item3 90* -6AN Fittings3 M14x1.5 to -6AN1 EZ-Clamp -6AN4FT -6AN SS Hose1 90* -4AN Steel Fitting1 Straight -4AN Steel Fitting9" SS hose -4AN1 7/16 Inverted Flare to -4AN restricted or open depending on turbo1 M12x1.0 to -4AN
Yes, thats great. That should be added to the article. Ask one of the mods to add that lists. It helps people get the parts and follow your diy better. Oh, and maybe catergorize that list for each turbo line for user friendly.The_Chosen_One wrote:The gold fittings can be found here at ATP
Unrestrictedhttp://www.atpturbo.com/Mercha...e=FTG
Restrictedhttp://www.atpturbo.com/Mercha...e=BCS
The Blue fitting can be found at jegs, anplumbing.com and summitracing
anplumbing.comPart# 9919BFE
Jegs.Part# 361-9919BFE http://www.jegs.com/webapp/wcs...79_-1
Summit RacingPart# EAR-9919BFEERLhttp://store.summitracing.com/...w=sku
The Big Coolant fittings for turbo and Block
ANplumbing.comPart# 9919EFH
JEGS.comPart# 361-9919DFH http://www.jegs.com/webapp/wcs...92_-1
Summit RacingPart# EAR-9919DFHERL http://store.summitracing.com/...w=sku
Those fittings should work on the SR20 S13 possibly S14 as well, I believe the S14 requires 1 more 6an fitting.HPR wrote:great info! I have some n00b questions though... will those fittings work on the SR20 as well (S14 to be exact)? and how do I know if I need a restricted/unrestricted fitting for the oil line? I have a GT28RS. I think I need a restricted one from what I've searched.
its all good this is what my hood looks like.themadscientist wrote:I can't believe you just laid those lines on your paint raw like that
those are burn marks from the engine bay catching on fire.ca18datsun510 wrote:are those **** stains?
