sideways24d »
https://forums.nicoclub.com/sideways24d-u64505.html
Thu May 24, 2007 8:44 pm
If you do end up getting a turbo, You Probably should get the MSD box. The Rev Limiter and the manual boost controller will come to use. Also you get more power with a complete combustion, I think you can all agree with that, so no, an MSD IS worth it. BUT NOT BY ITSELF. definetly get new injectors, SAFC, have good compression, Wideband O2. Increase your fuel, Air, (intake and exhaust) first, then Spark. An MSD is useless without these upgades. But your talkin mucho deniero here. The box alone is worth $600, and not to mention how much everything else costs. But Its worth it. Don't go cheap and go to Autozone. Try to use the manufacturers parts. They are expensive, BUT THEY WERE MADE FOR THAT CAR. Also try to find a good performance shop near you that does work on 240's. Get to be friends with the guys, you get your performance parts cheaper
