I didn't know how to make right thread after cut the threaded end. Obviously, you will have thicker end after you cut threaded portion. It was easier for me to just cut the middle and weld. Actually, I cut and weld two times because I didn't cut short enough first time and it was easy.themadscientist wrote:Why go through all that when you can cut the shaft off and rethread the end?
Every shifter I have ever seen is tapered. Cutting in the middle is the easiest way...Its def not easier to take it to a machine shop and have it turned down. esp. if you have a welder.themadscientist wrote:Well, the main problem, depending on the thickness at the shaft and at the threaded end, will be getting the diameter the same. Some shifters taper as in the pics, but some are not. If it's that steeply tapered you would need to take it to a machine shop to have it turned dow. As for the threading a good ole die will cut the threads for you. Like this.
Yeah...I was thinking about a s***ty weld job, and the same thing happening...that had to be a fun timethemadscientist wrote:Most people are more likely to have a local machine shop than a welder in the garage. Either way gets the job one. Just don't quit halfway like the guy that owned my friends Pulsar before him.
He was driving and went for second and the shifter snapped in half and gouged his hand. When we pulled the boot off we saw that someone had started to cut the shifter with a hacksaw and then changed their mind. Nice
this isnt about making a short throw shifter.justclay wrote:Get a B&M Short Shifter. Don't fabricate your own. It's an easy upgrade you can do yourself.
Yeah, this is exactly what I meant. I've already got a regular short throw, I just wanted it really short. It's almost like stock height. I've heard you could just cut them down, but with it tapered and I was sure if it was possible. Thanks!tramp_drift240 wrote:
its about making a SHORT short throw shifter. read the title.
ive got a b&m and ive still contemplated cutting a portion out of it so its not so tall.
That was B&M short shifter that I cut. B&M was still a little too long for me.justclay wrote:Get a B&M Short Shifter. Don't fabricate your own. It's an easy upgrade you can do yourself.
You cant be serious94_240sx wrote:That's what I did to mine and I love it. I think putting spacers between transmission cross member and chassis would work too. I ended up cutting more than what's in the picture. I did this after I drove a Miata NA with a short shifter.
zerothread?id=359607
sorry to get off topic again, but i cant find this anywhere.. where did you get the extension? i dont wanna cut and weld mine, id rather thread it all... but if push comes to shuv i got tig skillsrico05 wrote:I don't get the "short" shifter thing. I get the desire for shorter throws, but I actually added a 3" extension to get the shift knob closer to the wheel, ala rally type. But to each their own.
This has to be the worst idea i have heard.94_240sx wrote:I think putting spacers between transmission cross member and chassis would work too.
Um, if you get the die set. Thread it on your original threads, and BOOM, you have your thread pitch.That1Guy wrote:I can get my hands on a die set but what size do i cut it to?
Read the thread, young grasshopper. We know this. He HAS a short throw. He wants the actual shifter to be shorter.J14cm7 wrote:Umm i think you guys are missing the point of a short throw shifter. Short throw shifters are not shorter length wise they are so your shifts are shorter. if you take your stock shifter and cut it now you just have a really short long throw shifter. It would probably be near impossible to shift.
Just get a B&M and you will be shocked at the difference.
BTW i agree with david this thread is full of bad advice.
weeeeeeeeeell not really.. i use to have a 01ss maro and i cut the shifter real low like in the pic above and it helped.. those things come with huge fukn mac truck shifter that arent short throw... after cut,it was easer to get in gear .. but it was way the f*** down there on the floor hahaha and that was a painJ14cm7 wrote:Umm i think you guys are missing the point of a short throw shifter. Short throw shifters are not shorter length wise they are so your shifts are shorter. if you take your stock shifter and cut it now you just have a really short long throw shifter. It would probably be near impossible to shift.
pj wrote:enjuku has one
Yup, you misunderstood.....pj wrote:you just wanted an extension right? they have a threaded rod, male/female...it threads onto your existing shifter end to extend, should work with all nissan threads.
unless i just misunderstood what you wanted.
