how to make a custom air intake setup 4 your Q(no criticism please)
TBrack
Car: none
qsiguy wrote:I have one person waiting for one unless they've lost interest. I need to email him. I'm picking them up tomorrow.
already emailed you yesterday I think
Evanarc
Car: Roarin'94 Infiniti Q45
so wait, guy..pretty much u cut out the section of black plastic pipe that connects to the throttle bodyand reconnected the section w/ the vacuum seals to new stainless pipes?
Evanarc
qsiguy where did you buy those 2 pipes?
TBrack
Car: none
Evanarc wrote:so wait, guy..pretty much u cut out the section of black plastic pipe that connects to the throttle bodyand reconnected the section w/ the vacuum seals to new stainless pipes?
qsiguy
Car: 1994 Infiniti Q45 Turbo
Fabricated everything myself. I needed the MAF input for the turbo/BOV and the MAF to throttle body tube I blew a crack in it from boost pressure so I had to replace that one.
There are only two vacuum lines in that section and they are tapped into the silicone coupler near the MAF (you can see in the photo) and the 1" tube in the bottom of the small section between the MAF and throttle body needed to be connected.
You can see all the tubes that need to be reconnected in this photo
Evanarc
so qsiguy what are the measurements of those metal pipes you swapped in? any other advice on what material i should use?like those red clamps you have, where can I get em?
Evanarc
Evanarc wrote:so qsiguy what are the measurements of those metal pipes you swapped in?
let me take a guess at answering my own question:3 .5"?
qsiguy
Am I the only person who's actually trying to help this person get the information he wants regardless of what the rest of you want or think this person should do.
For crying out loud, if you have no useful input to the thread go away, it's really getting ridiculous.
Sorry Evan, don't judge us all by the actions of the few....
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
I'm actually interested in finding out how to do this. I'd really like to see a picture of Greg's setup. If it really gives the gains in acceleration, I don't see any reason not to do it. Even if it only changes the sound of the engine, I'm game. Did Greg ever post pictures of his mod? The way he described it in the thread made it sound really easy.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I'm planning on changing around my intake setup as well but am thinking about just doing a custom "box" for a cone filter to sit in and utilize the stock cold air inlet.
If I do the fender thing though that would allow me to remove the stock cold air inlet possible allowing more air to the condenser and radiator.
Haitian_King
mtcookson wrote:I'm planning on changing around my intake setup as well but am thinking about just doing a custom "box" for a cone filter to sit in and utilize the stock cold air inlet.
Please post pictures/write-up of it. I'd really like to see this being done and being able to see the steps involved.
Evanarc
I was pokin a round my 94 today and realized all the way to the right like on the drivers side of the engine compartment almost where the side marker lamp is, there is an outlet with a rubber splashguard..gave me some ideas..
qship96
Car: 1996 Infiniti Q45
Anyone going to a "cone" or other non-standard paper OEM type air filter, please post your used oil analysis to show you are not accelerating engine wear due to increased silicon {dirt} getting thru the fancy filter!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Where I locate my auxiliary ATF cooler because of protection from debris.
Originally it was for the Active Fluid cooler.
mtcookson
1992 Iinfiniti Q45
and much much more
qship96 wrote:Anyone going to a "cone" or other non-standard paper OEM type air filter, please post your used oil analysis to show you are not accelerating engine wear due to increased silicon {dirt} getting thru the fancy filter!
Probably going with the AEM dry filter so it should filter quite well... according to their marketing.
Will find out... though, having a 200k+ mile engine I'm not too worried about it.
qsiguy
Evanarc wrote:so qsiguy what are the measurements of those metal pipes you swapped in? any other advice on what material i should use?like those red clamps you have, where can I get em?
3.5" diameter. I got the stainless from Verocious Motorsports, an ebay seller. I also got the silicone couplers from them. I got a lot of stuff from them for my turbo project. I highly recommend them. I bought a straight section and several U bends in stainless 3.5" from them to use for making CAI's and various projects. You could make both pieces I did with one 3.5" U-bend and some 1" tubing. The 1" stuff I use at work so I had it around. You could probably find some aluminum tubing. I went with stainless because that's what I made my MAF flanges out of and wanted to use like metals so just went that route. You can't weld aluminum to stainless so that was out for most of it anyway.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Evanarc wrote:......and realized all the way to the right like on the drivers side of the engine compartment almost where the side marker lamp is, there is an outlet with a rubber splashguard..gave me some ideas..
It's tough to see but when you remove the airbox you'll see the hole going through to behind the headlights. This would also be a great place to get cold air.
I've got an OEM airtube from a base Q and a shorter air tube from a Qt if you want to try and fit up an inlet path without the expense of fabbing the SS tube from scratch. Your call.
qsiguy
Here is the MAF adapter I'm working on right now. Should have the part welded up this weekend. This one just has a 3.5" x 2" tube on it so the owner can connect to it and route their own tube wherever they want.
Haitian_King
Nice. You going to start making these in batches?
Evanarc
damn I wish I had seen those b4 I finished mine...
I ended up making a flange out of peices of a plastic dryer duct, and connected a 5" AEM CAI with a 4"-5" rubber drain connector & clamps from home depot..beats payin 35$+shipping for HTS equipment.
ALL in all I'd say the car preforms a lil better, and HITman was rightthe acceleration is more responsive, and it sounds like a mean m- fo.
See the pics here http://www.cardomain.com/id/evanarc
thanks to hitman, qsiguy & evrybody 4 the ideas
Haitian_King
Pics are a little small. I can't believe you put a bra on your Q. I've never seen that done to a Q before. Wow.
The intake looks good from what I can see. It looks nice.
qsiguy
I'm not going to make all adapters like this at once. I have a few more flange adapters cut out but I will custom make to order. Not everyone want's the same thing.
Evan, you must find an acceptable (for you) way to get the air filter out of the engine bay. I had mine like that for a while before I made the custom turn down one (pre turbo days) that went under the fender behind the bumper. I could tell a HUGE difference when the engine bay was cold vs. when it got hot under there. Subsantial decrease in horsepower. You'll notice it more in the summer time. If that's not a big concern that's your call. It does sound cool doesn't it?! I love how you can cruise around in stealth mode and how it roars to life when you punch it! (of course I like the turbo more, lol)
Evanarc
thanks I guess, thats just how I rollI detailed the front myself before christmas and decided 2 get the bra 4 extra coverage. I got the weatherproff winter cover 2.
More pics/ different concepts soon to come
I still got a bunch of stainless tubing to work into the mix, im thinkin the easiest way is to take air from where the wires for the driverside marker lamp goes.
it feels good4now, the air filter i bought is supposed to be high endurance heat resistant
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Haitian_King wrote: I can't believe you put a bra on your Q. I've never seen that done to a Q before.
The reason is knowledgeable car owners avoid them like the plague as trapped dirt from dust and rain make a fine polishing compound that grinds into the paint where the bra touches it.
Clear 3M type bras are the way to go the last ten years. Best if your paint is perfect, as in brand new or just filled, sanded and resprayed.
Haitian_King
maxnix wrote:The reason is knowledgeable car owners avoid them like the plague as trapped dirt from dust and rain make a fine polishing compound that grinds into the paint where the bra touches it.
Good to know. I'll definitely add that to my list after getting the repaint.
qsiguy
Finished the MAF adapter I was making. Looks like these will be $30 plus freight if anyone wants one. Not the cheapest MAF adapter but since these are low run custom made ones that's the best I can do for now. Doubt I'll ever do enough to bring the price down. Tig welded 304 stainless steel.
70 grit glass bead finish
Mild polish on the buffer
TBrack
Car: none
Man I'm pretty stoked, can't find things like this just anywhere!
mtcookson
1992 Iinfiniti Q45
and much much more
I'm interested in one. Can use it either on the Q or the Z.
