how to guide- audio system in pathfinder
ganesh21
Car: '12 Honda Pilot
you can contact me through my e-mail
Modified by ganesh21 at 1:09 PM 1/15/2008
ganesh21
below are the picture i promise
you have to take out a bracket. the bracket is for the manual pathfinder. just make sure to have something to cover the hole after. there is two bolt you have to take out.
as for the harness- i not sure if the Maxima one will work with the pathfinder. You can pick up a harness at any store. You will need a antenna harness.
this is on the driver side.
this picture is from inside. it is located behind the fuse box.
Path41489
Car: 2000 Nissan Pathfinder LE
Did anyone install a grommet in place of the plate that covered the hole in the firewall? If if so what measurement? thank you in advance
ganesh21
I just use Dynamat to cover hole.
WINNIPEGS_MOST_WANTED
Car: 2003 Nissan Pathfinder
I installed a grommet. Fit perfect - Unfortunately I don't remember what size it was... I would go out and measure but its Winnipeg and its -38 out there with the wind chill
Hey steve I e-mailed you the instructions along with pics at every step. Hope it helps.
timmack
Car: 2002 Nissan Pathfinder SE
ok i searched my a$$ off on here and cant find it.....anyone got a wiring diagram for the factory bose amp thats for the rear speakers?
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
timmack wrote:ok i searched my a$$ off on here and cant find it.....anyone got a wiring diagram for the factory bose amp thats for the rear speakers?
From the FSM for my '03:
http://www.digitalequilibrium....4.pnghttp://www.digitalequilibrium....5.pnghttp://www.digitalequilibrium....6.pnghttp://www.digitalequilibrium....7.pnghttp://www.digitalequilibrium....8.pnghttp://www.digitalequilibrium....9.png
timmack
right on, thanks. exactly what i was looking for. ill find out tonight if the '03 is the same as the '02. at least now i have something to go off of.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
For the dude that was asking about a better place for your amp, this is what I did. I'm not a fan of screwing it to your seats or box, that limits your system's mobility and there's always a cleaner way to do it. This allows me to easily remove my box and not worry about any obstructions when I've got to load the truck up. It was a lot of work but well worth it.
PS the power wires were not run like that, that was just for testing purposes. To eliminate engine noise I ended up running the RCA's under the carpet, up through the center console and into the dash.
Billy
greengumby
Car: 2002 Pathfinder- "ole Rusty"
2006 Honda Pilot
:worthless:
that's why a good thread should have been made into a write up :)
NismoPick
Car: 97 Infiniti QX4
00 BMW 528i E39
94 Geo Metro
87 Toyota Pickup
81 Datsun 280ZXT
greengumby wrote::worthless:
Not sure if you noticed this thread is 6 years old...
greengumby
2006 Honda Pilot
and the point is? .. it could be 6,10 , 30 yrs
I am on other sites that have much older threads but the write ups should have been placed in a pdf format or something in that matter to preserve the information.
