MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Wed Sep 04, 2002 4:10 pm
Ok.. so it's a bass tube.. I haven't heard that word in about 10 years.... don't get me wrong, I used to own one too, until band-pass boxes came about, then I realized they both pretty much suck... open-air enclosures with real subs are the BEST!!! But a Bass tube isn't bad, it'll do!
How many "bass-tube wires" are there? It sounds to me like the bass-tube might already be amplified internally... many of them are. If it has an onboard amp, it will have 2 or 4 speaker wires, a power source wire, and a ground wire. If it isn't it will have either 2 or 4 speaker wires only. If it has JUST 2 speaker wires, then and only then do you bridge the amp! Connect it as was described earlier. If it has 4 speaker wires.. wire them normally, it is the BEST way to do it.. If it has 2 or 4 speaker wires and power and ground wires, DON"T USE THE AMP!!!
