how to bridge an amp
Just another 240
I see, well is a little too late now because i already ordered my amp. I was planning to order a mono one but i was also thinking what if i order another bass tube? ya know wat i mean?
so what is crossover now?cause i see people use that word alot with audio system.
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
IN the specs you listed for the amp you ordered, it IS bridgeable and has a built in crossover unit. A crossover divides the signal frequencies. The amp you ordered has variable frequency crossovers for "high pass" and "low pass". In a nut shell, you can adjust how the frequencies are divided. Since this amp is going to be used on a sub... you want to cut out all of the high and mid frequencies in the signal, so that only the lower frequencies are amplified and sent to the sub. This makes for much better sound quality. You should be fine with this setup... but don't get all excited about a 8" sub... it won't blow your mind... but it will make some difference.
Just another 240
Oooo i see i see, thanks alot!
89sxRCR
Car: destroying self esteem
now if you go out and get 6 8's, then i would be impressed with that...BOOMIN
