Postby
greengt2nv »
https://forums.nicoclub.com/greengt2nv-u45265.htmlSat Feb 21, 2009 12:47 am
ok im replacing my clutch in my 91 240 and cant get the transmission back in for the life of me! anyone have any tips on doing so? PLEASE HELP!!! searching didn't help so don't bother with the same old "use the search" thanks
Modified by greengt2nv at 12:45 AM 2/24/2009
Postby
positron1 »
https://forums.nicoclub.com/positron1-u27022.htmlSat Feb 21, 2009 4:08 am
I straddled mine with both hands, stabbed it and after a couple of twists it went in. Just don't go crazy and ding it up. Are you trying to stab it by yourself or do you have someone to hold the engine?
Postby
greengt2nv »
https://forums.nicoclub.com/greengt2nv-u45265.htmlMon Feb 23, 2009 10:40 pm
another problem! blead the slave and the dampner and clutch will not release! still air in the lines????!!! f***ed up one new slave now onto the second one why wont it realease?
Postby
positron1 »
https://forums.nicoclub.com/positron1-u27022.htmlTue Feb 24, 2009 7:27 pm
What's the procedure you used? I opened the bleeder screw while someone pumped the clutch ten times and then I closed it while they held the clutch down. What did you do exactly?
Postby
S13-in-the-386-407 »
https://forums.nicoclub.com/s13-in-the-386-407-u24927.htmlTue Feb 24, 2009 8:54 pm
Are you sure its a case of the lines not being bleed? After reading your thread I'm thinking this is your first time doing a transmission on a 240sx. Are you sure you got the clutch fork and throw out bearing aligned corrrectly? I once had the same problem and what had happened to me is the fork seperated from the bearing from using a worn out spring. Just an idea.
Postby
greengt2nv »
https://forums.nicoclub.com/greengt2nv-u45265.htmlSat Feb 28, 2009 12:05 am
well still having a problem with the clutch catching. its like the clutch wont disengage all the way the car will move a little but it wont grab to its full potential! AHHH IM SO SICK OF IT! any ideas? i tried adjusting the clutch pedal rebleeding the system I don't get it. it did this with the bad clutch in it to. wtf!
Postby
H8HONDA »
https://forums.nicoclub.com/h8honda-u105795.htmlSat Feb 28, 2009 8:05 am
i just did a swap in my car and when i did the clutch i replaced the slave and master i also bought a stainless steel braided clutch line from enjku racing that goes directly from master to slave. it deletes the bleeder box and all that bs. and it makes bleeding the line very very easy. i do have a question did you make sure you were keeping the clutch res full when you were bleeding it???? if not thats your prob you still have air in the lines you gotta keep that full when bleeding. well thats my.02
