Why do you say rebuilding that T25 is futile? Rebuild parts are available, as well as at least one very competent shop (very close to my home). It may not be logical for someone who wants more power to rebuild a stocker, but for someone who's not looking for anything beyond what the factory turbo offers, why not?pirate87 wrote:rebuild is futile!
Sorry to say, but its just not worth it...and I am a huge proponent of fixing things before scrapping them.
rang dang diggy dig dang da dang....FREEBASE! Dont Do it!
Modified by pirate87 at 12:42 PM 3/12/2007
Well can you buy the bearing rebuild?I guess you'd have to press the other pieces back onto the shaft.GTR Shop wrote:Unless its a 32/33 GTR turbo, then throw it away. The shaft is the inner race of the bearings, pull the shaft, bearing falls apart and there is no way to get it back together
on another note, the turbine housing seems like it's cast to the CHRA, so as far as I can see you can't remove it. try and clock your turbine housing and see!GTR Shop wrote:For a start a T25 shares nothign in common with a RB20 or 25 turbo.T25s unless off a R34 GTR, S14 or S15 are all plain bearing and can be rebuilt,RB20-25 are all ball bearing. thy use the shaft as the inner race of the bearing.You can't buy the genuine bearings for them and if you could I'd like to see you assemble one! If you do do any type of overhaul on a RB20/25 turbo, then you end up replacing the CHRA with a plain bearing type ie std T3.
You can't put bigger wheels into a std core - end of story.
sorry but the pulsar GTIR does not come with a T25 turbo...however it is a T series turbo slighty bigger than a 25 its actually a T28 with a .86 A/R turbine housing either way it still wont work anyways for the flange is merely a T25 flange and not a T3 flangeSil240 wrote:NOPE.Bluebird uses the SR20DETWhich comes with a T25 turbo
The RB is some kind of T3 hybrid
??? I'm lost???GTi-R???I thought he said Bluebird, I must have missed it or somethingS14-NEO wrote:sorry but the pulsar GTIR does not come with a T25 turbo...however it is a T series turbo slighty bigger than a 25 its actually a T28 with a .86 A/R turbine housing either way it still wont work anyways for the flange is merely a T25 flange and not a T3 flange
Really.. Which generation engine do you have (R32 / R33 S1 / R33 S2)? I know my R33 S1 is metal, I have heard of this, but never seen one.Sil240 wrote:I pullled off the compressor housing and the Compressor wheel is PLASTIC.
