I'd suggest a Nismo power bar.j-z wrote:i know that toe is affected when camber is changed. i measured the toe of the car after i dropped it on its nuts and it was fine. plus its been pulling the same way since i bought it with stock suspension. i think the mount for the tension rod where it bolts to the body is ****ed up. like its bent up from bottoming out and i think it may have thrown the caster off a bit. thats the reason why i think thats what it is.
Nismo_Freak wrote:Hahhaha... I'd still rather have IRS w/ horrible camber gain than solid axle (solid axle ... verrrrry bad)
Solid axle is crap... why do you think the Cobra has IRS, why do you think the C5 has IRS. Solid axle means the entire axle is unsprung weight, including the 100+ lb. differential carrier. There is no gain in camber in the rear and the toe is static as a result.spitz7985 wrote:Solid axles have their place in racing. With a properly set up solid axle suspension, you can get over 100% anti squat (meaning the back of the car actually lifts instead of squats with hard acceleration). IRS you are limited to something like 25%. But, this is a handling thread/forum not a drag forum. Just thought I'd drop that bit of info.
\Nismo_Freak wrote:Solid axle is crap... why do you think the Cobra has IRS, why do you think the C5 has IRS. Solid axle means the entire axle is unsprung weight, including the 100+ lb. differential carrier. There is no gain in camber in the rear and the toe is static as a result.
Solid axle has no place in road racing.
chmercer wrote:err, why would you want the rear end to lift if you were doing drag racing?
chmercer wrote:right now i am running -2/-1 f/r camber and zero toe all around. i chewed the **** out of my front tires, the outside side is just about bald and the inside is almost on the wear bar, so i was thinking about adding another degree to the front, but should i go even higher? or is this tire wear pattern somthing different and i should leave my camber alone?
chmercer wrote:yea this is at a drift track. i aired them all to 35 before i left, they couldve cooled down but i would think the temperature wouldntve gone down much since its a 250 mile drive. but even if the pressure was way low, why would the outside be bald and the inside have tread, cause i know i dont have positive camber
spitz7985 wrote:Wait, I thought u said both edges of each front tire were worn but the middle wasn't worn as much...?
"i chewed the **** out of my front tires, the outside side is just about bald and the inside is almost on the wear bar"
C-Kwik wrote:Lateral loads on a tire on most suspensions will put the highest load on the outer edge of the tires. Keep in mind you have to factor in body roll when thinking about camber. While you likely have some negative camber at all 4 wheels, at rest(static camber), under lateral load, the car leans. Most cars tend to end up with less dynamic camber(the camber the tires see during a turn) since the car is leaning, taking up some of the static camber. Struts are notorious for this as they use a single lower arm and a fixed upper position. Double wishbone and it's multi-link variants are better at reducing this effect as it has some camber gain with compression, but dynamically, the camber usually does end up being less than static in most cars and suspension designs.
There are a couple ways to reduce this effect. Reduce body roll. This helps minimize dynamic changes in camber. The less the body rolls, the less the tires lean with the car. The other is to add more static camber. I'd try to reduce body roll first. Dialing in more static camber will put more load on the inner treads during braking and acceleration and have less grip available for both as well. But do keep in mind you don't want to be overly stiff on the body roll if it's a street car. It will make for a harsher ride and you do lose some of the independence of the independent suspension.
