unfrgivn wrote:Right now I have the rear camber adjusted to -2.6 which is as low as it will go (close to 0). I know a little negative camber in the rear can be good for certain applications, but how much do I want for mostly daily driving with a few road course events a year?
There are only 2 ideal setups for camber.unfrgivn wrote:Right now I have the rear camber adjusted to -2.6 which is as low as it will go (close to 0). I know a little negative camber in the rear can be good for certain applications, but how much do I want for mostly daily driving with a few road course events a year?
Def wrote:I've actually found that the optimal camber settings for street tires(-2 to -2.5* usually) and zero toe really don't wear the insides of the tires much if you are actually pushing the car to the limits of grip at least some of the time(autocross, road course). No matter how fast you think you drive on the street, there is absolutely no way you can get meaningful outside tire wear with all the straightline driving(mountain runs excluded).
So if you just cruise down the interstate, give up a little grip in the corners for tire life for YOUR driving. If you actually push the car, you can get even wear across the tread with up to -3* of camber on an MacPherson strut car and zero toe. The zero toe part is very important, because even 1/8" total toe in up front will chew up the insides of your tires very quickly with that much camber.
BTW - optimal camber settings differ depending on the tire used. The stiffer the carcass of the tire, the less that is needed. Yet the stickier the tread compound is, the more that is needed. That is why R-compound tires, even though they have a VERY stiff carcass, need alot of negative camber. They're just that grippy compared to a street tire.
Nismo_Freak wrote:You can't compare one car's ideal camber to another.. you can't even compare my ideal camber settings to your car. Simply put we have different dynamics.
Hahhaha... I'd still rather have IRS w/ horrible camber gain than solid axle (solid axle ... verrrrry bad)Q45tech wrote:My comments concerning 0.5 negative camber is what the tire wants to see! it is not the tires fault that the suspension camber gain curve is so sloppy or non existent that you have to preset so much extra negative camber to make it right under load.
http://www.pdm-racing.com/products/suspension.html
When you go racing invest in a pyrometer, I would suggest the needle type pyrometer's because they test actual tire temps rather than tire surface temps (by the time you get to test the tire the surface will have cooled faster than the inner tread).unfrgivn wrote:Thanks for all of the responses guys.
Ok well w/o correction bushings I can only get it to -2.6 in the rear. I have D2 coilovers with a 2-3 inch drop (closer to 2 I think). I really don't know a ton about suspension cause I'm more of an engine/mechanics/electronics guy, but I'm trying to learn. Mind you I do a lot of straight line driving, but these are only 1/2 year tires (march - october), but I also do autoxing and will be doing some road racing this summer.
Nismo_Freak wrote:Hahhaha... I'd still rather have IRS w/ horrible camber gain than solid axle (solid axle ... verrrrry bad)
Def wrote:The 5 pt multilink in the rear is just fine as far as camber gain goes.
The MacPherson strut suspension up front is what Q45Tech is talking about. It is very compact, but the camber gain is pretty poor for hard driving.
BTW - most of those "solid axle" cars have superior double A-arm suspension setups up front.
There is no magic number for a setup... you have to do a test and tune. If the F1 Ferrari team has to do test and tune, you have to do test and tune. Plain and simple, this is the ONLY method.j-z wrote:i understand. a good baseline guideline would be nice to get me started for now. like do i want more negative camber up front than the rear or what? you know basic stuff like that with some numbers to go by. thanks
sideshowbob wrote:I've got a question...and i didn't want to start a new thread
I have a set of spf1483k (front lower camber bushings) for a s14. Do i need them with tein s-tech springs... 1.3(f) 0.9(r) and how much camber ajustment is there upfront??
