How much boost...
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
can a t25G efficiently produce? Sorry for such a general question, but I can't find a good answer. I'm thinking maybe 18psi?
karmakaze
Car: 98 240sx SE
mmm240 wrote:can a t25G efficiently produce? Sorry for such a general question, but I can't find a good answer. I'm thinking maybe 18psi?
I assume you mean "25G" and check on a DSM forum. Those turbo's are not traditionally ran on Nissan's as they usually use a different type of flange.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I was under the assumption that it was the stock turbo for an s13 SR. Not So? Then what is?
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
t25 is the stock turbo for the red top and black top motors. t28 is for the s14 notch top and s15 motors
codyace
Car: S14 w/redtop
t25's are good for like, 14 psi without issue.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
IIRC T25s efficincy runs out around 14 or 15 PSI, anything more than that and your asking for a bunch of turbine blades to be scattered through your intake tract.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
SideWays=smiles wrote:your asking for a bunch of turbine blades to be scattered through your intake tract.
I've never heard of that effect. Does that really happen? I know for sure above 15 you'll be making a lot of pumping heat, increasing your intake temps, and not be making much extra power.
IanS
Yes it increases the heat, this heat coupled with the fact that the turbine is spinning much faster than it was ever meant to can quickly lead to the compressor wheel coming apart. Ive seen over boosted stock 1.8T turbos grenade from less than 10,000 miles of abuse.
Project240
Uh, yeah, 18psi is a terrible idea with a stock T25. There's absolutely no reason to boost above 14psi, you're just blowing hot air at that point and wearing your turbo out quicker.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I've seen turbine wheels vaporize as well from overboosting. It's interesting to pull a turbo off a mani and not see the turbine wheel anymore cause it melted and resolidified in the cat.
13 psi is about where you want to push a tired T25 to. 14 is doable, but you seriously comprimise the life span. 15 is just plain stupid and you will destroy that turbo post haste.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i turned my t25 up to 14psi and the power difference was amazing. i cant wait tell i get my new turbo put on and my car runing.
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
I believe that the t25g is the stock turbo on the later model avaneir sr20det. It has a gt-rs style intake and they were ball bearing center cartridges instead of journal bearing. But dont hold me to all of that. But i know that they have the gt-rs style intake housing. My friend has one from his swap in his g20
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
ok since this is how much boost. i got a questionmy gt2871r .64 which will be here tomorrow. what is the highest boost setting i can run.and the actuator that comes on it from garrett waht is it set at .
Emperor_Tha
18-19 psi safely. 20-22 is like pushing it
BuLLeTdrift
Car: 91 240sx fast baq
Running 10psi on a track only car ok for the long run?
IanS
BuLLeTdrift wrote:Running 10psi on a track only car ok for the long run?
With what turbo, and what other modifications?
BuLLeTdrift
Sorry i'm an idiot. just figured every1 knew my set up via brain waves.
Stock Red Top255 walbrosidemountT25Exhaust side of things will be done soon (mani, elbo 3" straight exhaust)New head gasket and some other new maintenance parts can't remember right now
Modified by BuLLeTdrift at 7:09 PM 1/7/2008
Emperor_Tha
throw a fmic and a fuel pump then you will be fine
