180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Apr 08, 2003 7:38 am
After a full tuneup and the use of the S-AFCII I get around 33 mpg on highway. Local streets, I'm not too sure about but I estimate I'm getting around 23 to 25mpg. This is on a s13 SOHC.
here's my tuneup list:- Bosch o2 sensor (my engine light did not come on but after I swapped this part my mileage was vastly improved)- 8.5mm Aurora Ignition wires (got it from PDM)- Nissan PCV Valve (Courtesy parts)- Nissan Distributor Cap (Courtesy Parts)- Nissan Distributor Rotor (Courtesy Parts)- NGK Iridium IX (local dealer)- Air Filter (K&N w/ cone adapter bought off ebay)- 300zx Fuel Filter (Courtesy Parts)- a whole lot of brake cleaner to clean my pulleys and front of the block (I dunno if that helped with my mileage but a black spot on my driveway later, she revved a bit faster ha ha ha)- Super AFC II w/ black face (local dealer)- and of course an oil change with this time a Fram X2 filter and Mobile 1
Here's the thing about the AFC, I was running a bit rich on the lower rpms under 3k, so I leaned it out a bit, about 4% for rpms < 3,000 (NOTE: will be different for your car most likely than not) and that improved my mileage about 3mpg for my 50 mile commute to school. If you're not willing to blow some serious $$$ for the AFC, by all means do the o2 sensor. I had great results with that one, the others were good too but not as monsterous an improvement like the o2 sensor was for me.
hope that one helps
