How long to cure painted rims?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I was just finishing the last (4th coat) of clear on my rims when I dinged the rim with the can and chipped it down to the aluminum. I'm a little concerned because it had been 3 full days since the last coat of paint. I did 2 coats of primer and 2 of paint. Used a whole can of each on (4) 15s. Figured that would be enough. Now I'm wondering about mounting the tires and them just getting all chewed up by the machine.
How much longer should I wait?
AZ89two4Tsx
What's the weather like? Is it humid?
I would say wait a few days and try to keep it in as warm and dry of a place you can.
E7-S14
Car: ess 14 foo!
first off what kind of paint?
rattle can(enamel) or automotive paint( acrylic)?
enamels don't cure, they dry. and are much less durable than acrylics with an automotive clear coat
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Enamel, I wish I would have known to buy acrylic. Next time I guess.
It's not humid. During the day, it's 70 and at night 40
E7-S14
Car: ess 14 foo!
well to spray acrylic based, you need a spray gun, compressor etc..
but for rattle can it will take a week or to where its fully set i and wont chip as easily when hit.
how well did you prep? cuz if it chipped so easily may be a prep issue, unless you hit it harder than your saying. cuz any paint will chip.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I didn't sand all the paint off. But got it to a consistent smoothness. 2 coats of primer, 30 minutes in between. 2 coats of paint an hour in between and 4 coats of clear an hour in between.
So, I shouldn't even bother having tires mounted and driving them yet?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I'm about to prep and paint my bimmer rims. Sounds like you could give me some tips?
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Hope this helps you and good luck on the rims-
painted-my-stock-rims-t451436.html
