A forum for the Nissan Pathfinder and Infiniti QX4.
Painted my stock rims
Postby slickroger » Sun Sep 20, 2009 10:53 pm
I painted my stock wheels because i was bored of them and its almost winter so its time to get them ready to go back on.
what i used
3 cans of Gloss Black
2 cans of Primer
1 can of Clear
600grit sandpaper
1 sheet of bristle board
and Tape
Before
I tapped up the silver ring that surrounds the Nissan symbol.
I scuffed with 600grit sandpaper and water. I used the cup brush on one but found that if you only use light sandpaper the surface stays smoother and gives a better shine. I then cut a sheet of bristle board in half taped it together and used it to cover my tire used the same template for all my wheels and it worked great.
Then I applied Primer
I scuffed bad spots that really stuck out then I applied the Gloss Black coat
Here is the finished product with the tape removed and clear coat applied.
Rims on the truck
Modified by slickroger at 5:57 PM 11/9/2009
Nico thread with some of my mods: http://forums.nicoclub.com/zerothread/350117
slickroger
Car: Nissan Pathfinder 2001
Postby naladude911 » Mon Sep 21, 2009 1:27 am
Looks boss. I want to get mine done eventually.
WAYYY too big on the sig pic. Size it down please. Thanks.
http://sphotos.ak.fbcdn.net/hphotos-ak- ... 9108_n.jpg
naladude911
Car: 2001 Infiniti QX4
Re: Painted my stock rims (slickroger)
Postby Freaker7113 » Mon Sep 21, 2009 1:35 pm
very well done just did mine today have the exact same rims i painted mine in a black metallic hammered paint they look pretty sweet just waint for them to dry then putting them on the truck tomorrow
Freaker7113
Car: 2001 Nissan Pathfinder LE
Postby BING23 » Mon Sep 21, 2009 3:54 pm
wow looks dope, how long did it take you to do?
BING23
Re: Painted my stock rims (Freaker7113)
Postby slickroger » Mon Sep 21, 2009 10:44 pm
Freaker7113 wrote:very well done just did mine today have the exact same rims i painted mine in a black metallic hammered paint they look pretty sweet just waint for them to dry then putting them on the truck tomorrow
You Got pics?
BING23 wrote:wow looks dope, how long did it take you to do?
It took me the whole weekend but I was doing a lot of other things so my drying periods were full nights and i would just pick up where i left off in the morning.
slickroger
Postby Qxxx4 » Tue Sep 22, 2009 1:29 am
nice work, really shiny, i wonder how the first gen qx4 3spoke rims would look painted that or a smoke grey.
Those new winter tires? how much did you pay for them? im on the fence if i should put a new set on my stock wheels
Toronto, Canada
1999.5 Infiniti QX4, 2012 Mustang V6
Qxxx4
Car: 1999.5 Infiniti QX4, 2012 Mustang
Re: Painted my stock rims (Qxxx4)
Postby JonathanPrem » Tue Sep 22, 2009 4:42 am
Man slick those are mad sexy. I'm definitely doing that. How much sanding should i do and how many coats of primer , glossy black and clear should i put on it.
02 Path-22" 's, Lowered, Full audio system-DD/Family whip
95 240sx- Black, Manual conversion,HSD coilovers, Origin rear bumper , Soon to be KA-T
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Re: Painted my stock rims (JonathanPrem)
Postby slickroger » Tue Sep 22, 2009 7:58 am
Qxxx4 wrote:nice work, really shiny, i wonder how the first gen qx4 3spoke rims would look painted that or a smoke grey.
I bought those tires last year and they ran me about $900 but there amazing in the snow.
JonathanPrem wrote:Man slick those are mad sexy. I'm definitely doing that. How much sanding should i do and how many coats of primer , glossy black and clear should i put on it.
I suggest using between 400 - 600grit sandpaper so you dont really dig or damage the rim with deep grooves and just make sure you sand everything. when painting the plastic covers you can tell where you didnt sand well because the paint wont stick properly.
i used one coat of primer and then re-sanded than painted re-sanded, than painted again and added clear coat.
2 cans of Primer
1 can of Clear
600grit sandpaper
and Tape
slickroger
Postby Freaker7113 » Tue Sep 22, 2009 2:05 pm
i'll get pics once i put the new rubber on em getting them sometime next week
Freaker7113
Postby JonathanPrem » Thu Oct 01, 2009 11:14 am
Slick got a quick question. I just sanded my rim with 600Grit sand paper and primed it. Do i spray the glossy black on or do i wet sand it then spray the black.
JonathanPrem
Postby slickroger » Thu Oct 01, 2009 11:21 am
I lightly water sanded with 600grit then sprayed. Than i did the same thing again before i put a second coat of black on. This was really to take out any Imperfections and over spray, I also don't have proper drying facilities so some spots had dust that stuck in the paint so i resprayed and covered it better.
Good luck
slickroger
Postby Densetsu » Thu Oct 01, 2009 1:21 pm
Looks sweet. Only two basecoats though? Interested to see if they chip easily, though I guess they're "only" winter rims so it won't be such a big deal.
Now all you have to do is paint those calipers and you'll have an awesome setup.
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
Re: Painted my stock rims (Densetsu)
Postby slickroger » Thu Oct 01, 2009 2:06 pm
there already yellow.
thats just an old pic
slickroger
Postby JonathanPrem » Sun Oct 04, 2009 1:58 pm
Slick have a major problem! I followed everything you said and when it came down to the clear coat. it came out wrong. I bought the exact clear coat you had in your picture but my rims didn't come out glossy black. Its more of a metallic black. What should i do? wet sand then glossy black it and not clear coat or just clean it off then polish it. I'll post some pictures later on.
Btw thanks for all your help.
JonathanPrem
Postby rlp » Sun Oct 04, 2009 2:05 pm
Looks NICE, real nice. I have orig qx4 3 spoke and want some black too, So thanks for the pics and looks like it can be done with excellent results.
rlp
Car: 03 QX4
Postby slickroger » Mon Oct 05, 2009 8:05 am
JonathanPrem wrote:Slick have a major problem! I followed everything you said and when it came down to the clear coat. it came out wrong. I bought the exact clear coat you had in your picture but my rims didn't come out glossy black. Its more of a metallic black. What should i do? wet sand then glossy black it and not clear coat or just clean it off then polish it. I'll post some pictures later on.
Put some pics up
Did you use the exact paint I used?
I also put a pretty thick coat of gloss I would let it dry and respray where I though I missed. These wheels took me a long time I had let the wheels have a lot of drying time between coats.
Where do you live I got lots of free time on my hands now.
rlp wrote:Looks NICE, real nice. I have orig qx4 3 spoke and want some black too, So thanks for the pics and looks like it can be done with excellent results.
Take your time, Prep is key and I think WOT did the three spoke and they look way better black
slickroger
Postby JonathanPrem » Mon Oct 05, 2009 11:29 am
hey slick,
Yea i used the exact sprayed you used. I took at least 15-20 mins sanding my rim with 600 grit And i ran into another problem. Its chipping pretty easy( put the cent cap on and try to take it off with flat head and it chipped a bit off. Here a pic from my iphone.
It not glossy black. its got a hint of grey in it know. Btw I'm near warden and 401 area.
JonathanPrem
Postby sicwitit » Mon Oct 05, 2009 11:46 am
JonathanPrem wrote:hey slick,
How long did you let each coat dry for, and what is the temp your painting in/curing in?
04 Pathy - now with JDM parts
IS300 - Time attack machine
99 STi Impreza RA - slowly turning into a rally car
98 STi Impreza wagon - currently forsale
some other skunk work projects in the backyard...
sicwitit
Car: part fabricator
Re: Painted my stock rims (sicwitit)
Postby JonathanPrem » Mon Oct 05, 2009 12:57 pm
i think i let it dry for 15-20 min and i did in my garage since it was colder outside. I would say roughly 15'C.
JonathanPrem
Postby slickroger » Mon Oct 05, 2009 4:09 pm
I let the paint coats dry for several hours between coats, the last black coat i left for a day and then applied the clear wheel coating in hourly intervals.
How many cans did you use it just looks like the coats you used might be too thin.
slickroger
Postby Empty V » Mon Oct 05, 2009 7:27 pm
Dude those looks sick! Nice work man they look pro, quality for sure. I thought about having mine powdercoated glossy black and then selling them when the new ones arrive.
Billy
Quote, originally posted by Ace2cool »
Your QX4 looks gay. I hate the lights on the roof. Why would you put a bull bar on it? I doubt that thing has ever seen dirt, much less mud. Infinitis don't belong offroad anyways. What are you, in high school and putting s*** you think looks cool on your parent's car? Get a real offroad vehicle.
Empty V
Car: 2001 Infiniti QX4, 1982 Corvette C3 Shark, 2001 Lexus RX300, 1996 Bayliner 4788
Re: Painted my stock rims (Empty V)
Postby slickroger » Tue Oct 06, 2009 6:41 am
Empty V wrote:Dude those looks sick! Nice work man they look pro, quality for sure. I thought about having mine powdercoated glossy black and then selling them when the new ones arrive.
Billy
Sounds like a good plan I haven't driven with them yet, so i'm just hoping they hold up well against chipping I obviously didn't want to test my self because the paint looked so good when i was done. but we shall see soon
slickroger
Postby W O T » Tue Oct 06, 2009 7:34 am
Waiting hours between coats is actually to long, 10 minutes is perfect, right after the last coat tacks up, the layers bond together instead of just laying ntop of each other. The thing that will help ya with chipping is waiting a full day before exposing them to abuse and letting them cure in 70-85* temp, paint dont like the cold
My rims havent chipped at all and I beat them daily on rocky roads
Built... Not Bought
W O T
Car: 2001 Infiniti Qx4
Postby JonathanPrem » Tue Oct 06, 2009 7:56 am
slickroger wrote:I let the paint coats dry for several hours between coats, the last black coat i left for a day and then applied the clear wheel coating in hourly intervals.
I bought 3 cans of glossy black and i used up 2 full cans and bit of 3 third.
JonathanPrem
Re: Painted my stock rims (W O T)
Postby slickroger » Tue Oct 06, 2009 8:08 am
I'm not an expert when it comes to painting in fact this is really my first painting project. All I am saying is what I did when I painted my wheels because he asked so don't take my word as professional advice, Its just what I did.
I have left my wheels for a couple weeks in the garage not at the temperature you said for curing but will this be sufficient as i dont really have any where thats really warm to place them?
Just trying to get some chip prevention going on
slickroger
Postby quagmyer402 » Wed Mar 03, 2010 8:27 pm
i live in fl and right now its at perfect curing temp, but I wasn't going to paint them myself. I have a friend who does excellent body and paint work, he did an amazing paint on on my dads 75 corvette and he said to make it look professional take it to a professional. he said the price ranges 100-200 for all 4, but prices are different in all states. I was going to paint them black and where you taped off around the emblem and kept silver im doing the same but painting the circle white. And he said it could be done in an hour n half, prep to gloss.
quagmyer402
Car: 2001 nissan pathfinder LE
Postby GRNMACHINE » Sun Jun 20, 2010 6:02 am
Nice write up slick! I plan on giving this a try soon.
2 questions:
How are they holding up after winter?
What step do I use the bottle of Heineken? :confused:
Could have had 70 more HP if I only waited 18 months.....
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Postby Anamagous » Sat Nov 05, 2011 5:01 pm
Hey guys,
what about the inside of the rim, I have the 3 spoke infinity rims and i am worried that the inside will show, did you paint yours inside? thanks
Anamagous
Car: 2000 Pathfinder
Postby PathDetector » Wed Dec 14, 2011 12:59 am
Hoping to put some paint on my wheels soon! Know its an old thread, but thanks for the post. haha
Anamagous wrote:Hey guys,
I'm planning on painting the whole wheel. I'm no expert but I'd say the stock rim color will show and give a half a**'d appearance. Might as well be thorough with your paint job right? :biggrin:
PathDetector
Car: 2002 Nissan Pathfinder SE
Return to Pathfinder Forum / QX4 Forum
