It's all a matter of preventative maintenance and how the previous owner cared for such.dabum wrote:i recently jus purchased a 1992 240sx coupe with 280km on it, im plannin to do a motor swap in tha summer but im jus wonderin how long this motor can last. tha previous owner has taken good care of tha car nd apprently has only used synthetic oil since tha motor hit 100k.
Thanks
on a more serious note. i can't remember which one it was, but one of this months import mags dyno'ed a completely stock 95 s14. iirc, it had around 120k + miles on the odometer and put down some 130hp to the wheels. not bad for a well maintained truck motorESPER wrote:1989 w/352,010 miles dynoed at 133 rwhp
Yeah, those little leaks piss me off. I had to keep cleaning my driveway until I used a thicker weight with some restorer which settled it down some.Scott McLellan wrote:This is all good news since mine has "only" 133K. Have you ever noticed how running synthetic oils makes you have little tiny leaks. I put Redline transmission fluid in my transmission and now there is always a little drip hanging from all the sensors and stuff. I thought that maybe I just didn't notice the drips before I replaced the fluid maybe but I recently read in a car mag called Auto Restorer about how if your engine has more than around 30K miles, it could have these little leaks. Leaks is probly a bad word for it as it probly drips once a week. They also said that if you put normal oil back in it won't stop the leaks, too. The leaks don't hurt anything just keep the fluid levels topped off.
