How light can a s13 get?
Edub1
Car: 89 240sx KA-T
I can see doing that stuff to a race car, not a street car.
Also, it seems more cost effective just to ad a few more HP. CF doors are like $1,800 each.
I do wonder how much weight would be shed by going with an aluminum fuel cell.
SPIRONIUM
Car: 240RS group 2
Mine is exactly 2305lbs with half a roll cage, although i did cut out a lot of metal and i have a carbon hatch. I removed close to 20lbs of wiring without a custom harness just cutting out wires i'm not using. A good place to remove weight without welding and reinforcing which a lot of people don't notice is on the cockpit side of the firewall, there is a thin sheet of metal and sandwiched between that and the firewall is hidden sound deadening that seems to be overlooked a lot. If you remove all sound deadening and carpet stuff its an easy 60+lbs of weight.
Under 2300 is NOT doable without extensive modification like the dent sport guys, and if you don't want to cut out anything be prepared to waste a lot on carbon fiber which is not worth it at all if you have any kind of budget normally associated with 240sx owners damnit
Has anyone acid dipped their s13? Do people still do this i havn't talked anyone who has
thekawaii
Car: box with 4 wheels
Edub1 wrote:Also, it seems more cost effective just to ad a few more HP. CF doors are like $1,800 each.
Is it 1200 dollar for both side?
naed240sx
Car: .....
More horsepower won't help handling and braking
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
convert the entire wiring harness into a serial data bus that uses few data wires. thats proven to be much lighter.
hannibal
Car: Red Line to Glenmont
Dude, that car is basically tube framed in the rear. I dont know if you can call that an S13 anymore...
But yeah, 1926lbs is rediculously light...
Chezedik
Car: 1991 Nissan 240sx
about 8 lbs.
naed240sx
Car: .....
IWannaS15 wrote:Dude, that car is basically tube framed in the rear. I dont know if you can call that an S13 anymore...
not really, the load bearing components of the rear chassis are still unibody.
drEameRvaJ
Car: 1997 Nissan 240SX SE
brokeAs240sx wrote:are these numbers u guys are coming up w/ the actual weight of ur 240 (i.e. you brought it somewhere and had it weighed)? or are you guys just taking the stock website curb weight & subtracting stuff?
Reason I bring this up is because, for example, the 240 vert is listed as 2800lbs, I weighed in @ just over 3100 stock. The 2800lbs is dry weight (no gas, no fluids, etc). So I was curious to see what everyone's coupes & hatches weigh.
WHOA! A vert' 240 weights 3100lbs? DAMN! I wonder how much my 97-98 weights. Gesh, 3100lbs is a lot.
reu
Car: 89-240sx(x2)
hey everyones deducting thier body weight 2 right?plus not having any power options helps.doesnt a gallon of gas weight 5 lbs?remember 2 weight on "e".i weight 2600 on "e" stripped without me in the car but its an "89 hatch.damn coupes are always gonna be lighter huh! i weighed mine at a rock quarry, so dont know how accurate though
Dustin240
A gallon of gas is 8lbs.
onosqv
Car: '92 240sx Vert
Yes, when I weighed mine, body weight was deducted. I sat in the car to get the crossweights also (which is in another post).
onosqv
Car: '92 240sx Vert
reu wrote:remember 2 weight on "e".
No point in weighing it on "e"... why, so I can say I have the lightest car in the world? It's about as useful as claiming weight loss by weighing yourself before and after taking a dump...
In any case, part of the reason for some gas is that you're suppose to weigh it & balance it as it will become during tracking time (I expect to be half tank toward the the middle/end of the race) and w/ walbro pump, it is recommended to be at least half tank to insulate the fuel pump.
