johngriff »
https://forums.nicoclub.com/johngriff-u30588.html
Sun Sep 23, 2007 1:45 pm
Just because the SR can handle detonating and running lean on a whimpy t2, doesnt mean he is taking advantage of good fuel mapping and good ignition mapping.
Good AF/R + Good Ignition Timing = power. If the ecu doesn't have values for that much air, it will only send its maximum, which is too little to really justify running that much boost.
Once you re-chip, or tune it using Emanage,FIC, Haltech, Power FC etc, then you can take real safe advantage of the extra air. Air alone does not make more power.
