ska69 wrote:300 for rods is too much for me, as I'd prefer to spend that on something else for my car
My plan is to rebuild the engine in stock(w/o turbo) using pulsar nx ca18de parts and a bit more from other engines.
Here is what I was thinking:
camshafts - stock (iirc, exhaust camshaft from ca18de)
crankshaft - leaving the current ca18de crank
pistons - found some @ a good price in Australia...look stock and new.
piston rings - pulsar nx
connecting rods - pulsar nx (found remaned)
connecting rod bearings - pulsar nx
crankshaft (main?) bearings - pulsar nx
valve intake - pulsar nx
valve exhaust - only ca18det?
timing belt tensioner - pulsar nx
idler pulley - pulsar nx
valve guides intake - (maxima a32 (vq20/30de), also vq35de, vq40de, ca16,ca18)
valve guides exhaust - (primera p10 (sr20de, pretty much any sr20de engine)
gaskets - either cometic or nissan oem
injectors - leaving stock for now
water pump - ca18et
oil pump - ca18de
alternator - '91 ka24e
starter - '89 pulsar or '86 200sx/stanza
p/s pump - I suppose electric pump
a/c compressor - any matching to the stock one (forgot the correct model)
engine mounts - I currently have subaru mounts, they are in good condition and I'm going to leave them
sensors and other engine electric stuff - replace with new parts
I'm not sure what else should be replaced in case of total overhaul, so suggestions and comments are welcome
