Hehehe. I <3 your spelling Bri.WDRacing wrote:
Yeah...why don't you NOT worry about KAT relted threads
I will try! give me your numbers sir, I will give it the old college try (if I dont get it the first time, get falling down drunk and try it again. But to be on Topic: I am a Huge SR slut. Love them. want one to have thousands of my little babies. But that doesnt mean there is anything wrong with the KA. Its not bad just different. Elgarvo616 try READING before you go making outlandish statements. The Ka can make torgue that would cause an SR to weep openly and throw itself on the ground while gnashing its teeth. The SR makes the silvia a almost perfectly balanced high HP drifting/racing machine. Each side has its ups and downs and its more about the driver and what they like/want/need than whether or not "Ka'S RUl3 SR M0t0rs" or vice versa.WDRacing wrote:Psssssht...you try drinking a 1/10 of my usual diet and see how well you type
SURE you can...just need to filter it through a paper towel...lol.joenismos15 wrote:I didnt Know you could drink Denatured alcohol WD
To drink as much as I do, you have to admittedly be an alcoholic I'm trying to cut down...but sometimes it gets the better of me.BigMACKenzie wrote: I will try! give me your numbers sir, I will give it the old college try (if I dont get it the first time, get falling down drunk and try it again. But to be on Topic: I am a Huge SR slut. Love them. want one to have thousands of my little babies. But that doesnt mean there is anything wrong with the KA. Its not bad just different. Elgarvo616 try READING before you go making outlandish statements. The Ka can make torgue that would cause an SR to weep openly and throw itself on the ground while gnashing its teeth. The SR makes the silvia a almost perfectly balanced high HP drifting/racing machine. Each side has its ups and downs and its more about the driver and what they like/want/need than whether or not "Ka'S RUl3 SR M0t0rs" or vice versa.
I've driven both the SR and KAT at autox and I prefer the KAT over the SR anyday due to the fact that it has more low end torque.silverkouki wrote:Im wondering how good the KA-T setup is on the track...Im not talking about drifting (cuz I know it does well), im talkin about circuit racing and grip. I havent heard that much about KA-T's killing it on the circuit, and many people tell me that KA-T's require alot of finesse on the gas (due to massive torque) so its supposedly a little harder to get used to (rather than throwing the chassis around drifting).
So are there any 'famous' KA-T track cars out there that do really well on the track? And for people who already have the set up, how do you think it does with circuit racing?
Maybe Nissan will put this in the S16...WDRacing wrote:The best design would have been a hybrid CA18 KA24 SR20 masterpiece. Take the aluminum block from the SR, the design of the CA18 and the stroke of the KA with a fully counter weighted crank and achieve a 2.2 screamer that can produce torque and still rev to 8000rpm is factory form while being lighter then the entire RB series. But I'm just a dreamer...
WD
whats wrong with jacking of to the ka's extra 400 cc's.....? i do it all the timeredtop91 wrote:You need to do some research. The SR doesn't have rocker arm stoppers. People add them to it. Way to prove how much of a dumbass you are. Spend the time you are trying to pull your foot out of your mouth learning how each engine has its advantages instead of jacking off to the KA's 400 extra cc of displacement. Tard.
hahahaha the mere fact that it need these rocker arm stoppers is reason enough to avoid this motor, the money that you shell out to make power on the sr is much better spent building up the KA with its awesome 400cc's extra displacement and the torque advantage........if you havent ever experianced the ka the you need to, because past all the fanboy JDM'ness of the motor there is nothing that makes it special, infact if you do want to do some research, do this... the sr was made at a time when nissan motors was not doing so well , hence these motors these SR20det's that you so aimlessly bow down to are nothing more than fanboy HYPE.redtop91 wrote:You need to do some research. The SR doesn't have rocker arm stoppers. People add them to it. Way to prove how much of a dumbass you are. Spend the time you are trying to pull your foot out of your mouth learning how each engine has its advantages instead of jacking off to the KA's 400 extra cc of displacement. Tard.
+1I Jack-Off to my ka-t. Man it is as good as p0rn, actually whenever i floor the gas pedal i cant control the feeling, it's like a getting a bj from a HOT *** girl while driving.LOL All the torque is like having a never ending climax.shahabshaukat wrote:
I'm much happier jacking off to the extra 400 cc's pf displacement then to some fukkin jdm fanboy garbage.
Peace Bitcch
First off, spouting ignorance doesn't do much to support your cause man. If the SR was such a bad motor designed because Nissan was doing badly at that particular time, how do you explain it being designed by the same team that built the RB26? Also, how do you explain that it still currently resides in the S15 chassis many many years after Nissan came out of the slump? And finally the rocker arm statement...this mod does not need to be done on SR's that retain there stock rev limit.shahabshaukat wrote:
Peace Bitcch
Not really. The SR has a powerband the KA can only dream of spinning up to so the only people that buy RAS are those who plan on drifting and even then it's only as insurance against REALLY overreving the engine. I've revved my SR to 8700 bone stock. The SR does NOT NEED RAS. And are you really saying that a $150, 30 minute mod is a reason to avoid a motor? Yeah I'm sticking with my original argument. You are a retard.shahabshaukat wrote:
What money I shell out? Redtop SR's can be had for $1500. Slap on a GT30R, some 740's, cams and a rom tune and you are making 400+ WHP all day. With the KA you are still shelling out money for internals at that point. And for what? 40 extra lb ft and loosing that at your 6500 RPM redline? Sorry I'll still be in gear making the torque that is your only claim to fame that you are now having to build back up. Save the torque argument when you are making turbo diesel torque. The torque of any 4 cylinder is only impressive to ricers and noobs.shahabshaukat wrote:the money that you shell out to make power on the sr is much better spent building up the KA with its awesome 400cc's extra displacement and the torque advantage
Balanced crank, better internals, better breathing ability, lighter, bigger aftermarket support just to name a few. Again this is something all KA fanboy's say. Just because someone got a motor that came in the car in Japan doesn't make them a fanboy. The fact that you think that makes you even further a PDS rehab dropout. The SR and CA came in every other market except the United States. It doesn't make the SR JDM tyte it makes the KA the bastard red headed step child.shahabshaukat wrote:because past all the fanboy JDM'ness of the motor there is nothing that makes it special
Ummmmmmmmm there is no train of reason or logic to directly equate Nissan's profitability to the SR's quality. GM is reporting record losses when their car's have never been powered by more reliable, efficient, and powerful engines. Picking your weak argument apart is a walk in the park.shahabshaukat wrote:the sr was made at a time when nissan motors was not doing so well , hence these motors these SR20det's that you so aimlessly bow down to are nothing more than fanboy HYPE.
I'll paypal you $10 if you can even find where I remotely even suggested that the KA was inferior to the SR. My only argument has been they are different and done right they are both pretty much equals.WDRacing wrote:
Ryon, you FAIL for not realizing that the KA, albeit it being a heavier motor, is every bit as good as the SR. The aftermarket has finally caught up so that can't be considered anymore. What you're left with is a motor that has 400cc more displacement that without question yields more low end torque then the SR is capable of. The only reason there are so many problems with the KA is because people in general are lazy and stupid. They cheap out on essential things and ignore proven methods of success. But compare the KAT's that are built by guys with any knowledge at all and you have a platform that is every bit as competitive as the SR.
Power under the curve is what all racing is about. Because a motor can rev higher is a good thing, but the KA does NOT have a rev limit of 6500. This goes back to my, educated discussion comment. If I had an SR in my S14 I certainly wouldn't remove it in favor of the heavy *** KA...so my opinion isn't biased. The KA has been proven to consistantly make over 400whp with just the installation of a T3/TO4E and a rom tune coupled with 20 psi of boost. This was done at 6300 rpm. That gave Fiznat a useable 3500 rpms of real power. When in ANY type of racing, you don't leave the rpm band. Drifing included...if you are going to argue, then explain why I've seen diesels swapped into Miata's?redtop91 wrote:What money I shell out? Redtop SR's can be had for $1500. Slap on a GT30R, some 740's, cams and a rom tune and you are making 400+ WHP all day. With the KA you are still shelling out money for internals at that point. And for what? 40 extra lb ft and loosing that at your 6500 RPM redline? Sorry I'll still be in gear making the torque that is your only claim to fame that you are now having to build back up. Save the torque argument when you are making turbo diesel torque. The torque of any 4 cylinder is only impressive to ricers and noobs.
Depends on what type of racing...Ryon is only a couple hrs away from me. But he know's he'd get owned at the drag strip...then again, Ryons SR does not have a rod on the wrong side of the block My S14 has been down for close to 3 years now. But she's got plans that are coming together. Just involves some fabrication, a new motor, internals that can sustain insane boot levels and enough alcohol to kill an entire herd of cows240sxvaj wrote:You guys should have a ka24de-t vs sr20det race. No arguing and just let the cars talk for itself. also make a video, i would love to see this.
nice examples/vids- good job kicking a$$ and reaching 2nd... power is definitely not everything in this case do you have any vids with the in-car cockpit view?Biggamehit wrote:
zerothread/348269
however even in a straight line i run 13s..... so if they slipped up/can't drive, i would beat them.... drag FTL so not cool anymore to me..
the thread was about how KA-T's do at the track... i had 25plus runs yesterday and the KA was awesome once again
Do you own the bar? Do they serve Kilkenny? It's also not wise to challenge someone of Irish/Scottish/Welsh decent to ANYTHING. Because I will cheat if need beFlorida240sx wrote:ITo settle the drinking yall fly down here to FL. We'll drink some Guiness at my bar... just so you know I just now got home from it.
Challenging a bartender is usually not the wiset of ideas.
