AZhitman wrote:The Zoop is NOT a polish.
It will not make aluminum any shinier than it is, it's a protectant.
PMQ, you're doing somethnig wrong. Aluminum is pretty easy to bring to a "chrome-like" finish. Bet you skimped on a step or on supplies.
I'll be glad to help if you'll detail what you've done thus far.
First step:Dry sanded the part with 120 grit. Then wet sanded it with the 120 grit. Wet sand with 320. Wet sand with 400. Wt sand with 600. All grits were used for atleast 5minutes per 4x4in area. Then I wiped the whole part down with a dry cloth. Then I applied the mother's polish. Built up alot of black residue. Added more polish when residue started to disappear. I think I may not have rubbed the residue on long enough.
How do you know when the metal is as polished as it's going to get? Is there a way?
Should I have dry sanded up to a higher grit and then started wet sanding?
