EazyBreazy wrote:
that is absolutely the worst possible way to merge the two fenders together man, did you even bother looking at the body lines around the fender and compare the two. They are completely different and if you do not include the entire upper arch of the wheel well then you will wind up with an abomination of a car.
read the link he posted, its virtually the same for s14 and s13 when doing this conversion, no matter what you need the entire wheel well off of the s15 fender put onto the stock s14/13 fender otherwise you'll have the abomination i spoke of earleir
Thanks for clearing that up!I thought it sounded like a weird idea too, especially when the fender guy I talked to yesterday voiced the same concerns. I figured that since someone had done it the way the picture showed it had to be true, but obviously not.
Again, does anyone have pictures or PERSONAL experience?
