That car isn't even low, it just has a STUPIDLY low sideskirt...and it looks terrible.OM3GA wrote:
I do if boobs are involved.....Hoffman5982 wrote:tramp_drift240 wrote: noone likes an attention whore
i didnt say it was "hot" and frankly i dont go after cars for my sexual pleasures. its low as hell. you can post up those pictures if you want, but it all depends what parts you use. my exhaust isnt the lowest part of my car, but i already had a thick steel plate welded onto my resonator for scraping purposes. and crossmembers take a lot of damage, as ive already said.S14toRPS13 wrote:...and your car's not even that hot. It's low enough. I could post up uderside pictures, but you should already know that the frame, exhaust, crossmembers hangs lower than the body of the car.tramp_drift240 wrote: ^ that hatch isnt even that low
i do have matching wheels. those are drift spares. until you do something with your car other than keep it in like-stock condition, get over "yourslef".Hoffman5982 wrote:tramp_drift240 wrote:i feel like my cars far lower than most in this thread.
Full of yourself much?
you cant put a knuckle between my sway bar and the pavement in a level parking lot. and thats after a third of its thickness has been scraped off.
a friend of mine (drunk night) tossed my keys and they slid under my car. they had to lift up the rear end and push my car forward just to get the keys. no fitting under frame rails.
Yep, I think so. You can brag when you have matching paint on all panels and matching wheels.Until then, get over yourslef. As stated above, your car doesn't look all that great. noone likes an attention whore
You, kind sir, are very special.bigs1 wrote:That car isn't even low, it just has a STUPIDLY low sideskirt...and it looks terrible.OM3GA wrote:
LOLi do have matching wheels. those are drift spares. until you do something with your car other than keep it in like-stock condition, get over "yourslef".
i just dont see why people act like theyre part of the small group of frame bangers when they definitely arent.
foam much?
foam much?
There is also a point where you need to learn how to work on your own car.breadbox wrote:My car has a 2" drop from stock and barely scraped getting on the lift at the exhaust shop and he used boards.
There is a point where people will refuse to lift your car.
ILoveMyRHS13 wrote:There is also a point where you need to learn how to work on your own car.breadbox wrote:My car has a 2" drop from stock and barely scraped getting on the lift at the exhaust shop and he used boards.
Hold up there! If I work on my car, I get fined by the condo board... $75 each violation. I have to work on my car in store parking lots - the guys at the parts store are getting tired of me. Not to mention there are just some things that are best done on a lift. Don't hate!ILoveMyRHS13 wrote:There is also a point where you need to learn how to work on your own car.
To be honest, I've never really wanted a slammed car, but able able to run a sticker the says "Frame Banger" gives me second thoughts...S14toRPS13 wrote:Frame bangers?Sounds like a p0rn site.
