that looks righthsingh2088 wrote:Is #2 the right component to purchase?
I'm delighted to have made a contribution. If it were not for your guide, I would never have attempted to do it on my own. I should have provided the back story on what really got me researching bearings and the process to replace. It was an estimate of $1,800 to replace both front bearings! I brought the car to a local shop (in Bedford, Nova Scotia) called "Coast Tire" which I had a little confidence in. They drove the car and concluded that I should replace both bearings. It gets better. They said that "the ABS sensors often break when replacing the bearing so they wanted to have new ones available before proceeding". They said the two ABS sensors were about $800 for the pair. The two bearings and the labour was the other $1,000. Again, they made these recommendations based on a test drive only. I paid them $35 for the assessment and then took the car home. My sense was that only the right side bearing was worn. I jacked the car up and checked for play and only found it in the right side. I ordered the bearing online from a Canadian supplier for $135 delivered. The ABS sensors are sealed plastic probes inserted into what appears to be an aluminum bore. The only way I could see them getting broken is if someone (incompetent) tried to remove the bearing without first removing the sensor.asavage wrote:I'm glad you posted the differences with the X version, Thanks.
asavage wrote:Do you mean, removing #4 from #1?
(click on image for larger)
If so, on the RWD version there's enough room to swing the hammer at the hub. I imagine that for the AWD version, I'd have to use a drift and alternate on one side of the CV joint and the other, my helper turning the wheel full-lock alternately, but that's only a guess from doing this job on other vehicles with a similar setup.
You can't trust technology, it's not reliable.PJS3 wrote:I soooo wish the pics to this how-to were available.
