i dont rice around at full throttle. i could just drive around normal, as long as my bov opens, if i dont brup the throttle lightly as the revs come down around 2k, then it dies. i was going to try to adjust the bov spring so its harder to open, then cruising should be good and it would work at higher boost levels. i would recirculate it, but my bov is by the t/b and its a long run back to the afm. ahhhhhhh.redtop91 wrote:OP, If you want to run atmospherically then either run a blow thru, MAP, or stop ricing around at full throttle and letting off so people can hear your BOV. Or maybe you can recirculate...
thats a blow through mafs.FRoSt415 wrote:i've seen ppl move the MAF sensor to the throttle body side. just food for thought.
Ian for president!FlatBlackIan wrote:When will you kids learn? Just recirculate the freakin thing, the car will run better, you don't get soot on your bumper, you get better gas mileage, and you attract less unwanted attention. I just don't get it, there is no legitimate reason to run an atmospheric system on a street car, especially with a stock ECU.
As for blow through setups. Ive seen how long they last. Plan on cleaning your MAFs at least once a month, and if you have any blowby, you will be replacing it on a regular basis. Nissan MAFs were never meant to see pressure, nor were they ever designed to have an old turbo flinging oil at them all day long.
RPS13 DRIFTER wrote:mine only does it if i drive it hard and just push the clutch in from high RPMs and let it idle.
