How do i take of air filter box?
Faja
Car: 2009 Nissan Sentra
LOL - took you long enough!!! Just poke a wire hanger thru' the existing wires, tape up the end so you don't punch anything and see where it's coming out down by the brake pedal. You might have to make a small cut in a rubber piece by the pedal (IIRC) so the wires come out easily. After that it's a piece of cake.
bakerboard
Car: 2007 Nissan Sentra S 2.0
haha i know im just learning about my car!
This is where ill be sticking the wire thru correct?
Faja
Yep!!
bakerboard
Well i tried it out and got the wire thru i needed to get thru. I got the swicth all hooked up just need to put the air intake back in and hook up the battery.
I added a little male connector so i can could make the wire longer if it need to go to the battery.....Does this wire with the fuse go to the positive terminal of the battery?
Also, here is my swicth!!!
bakerboard
Faja I sent you an email
aebstract
Car: 09 Sentra SE-R Spec V
What is the switch for?
bakerboard
Turns foglights on or off
