nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Sun Sep 21, 2014 8:35 pm
First off welcome to the forum! I really like that color and the interior looks good from here lol.
Now as for what you can do as far as HP upgrades:
1. K&N intake kit (probably won't do much unless you have a higher output exhaust to go with it).
2. Rather than get a K&N system, make your own CAI or ram intake from the airbox down using PVC or aluminum piping. It sounds really jakey I know, but it can and does work. I am in the process of doing it now with PVC to test any gains and then I am going to invest in aluminum if I can find a good setup. With my current setup I have removed the factory resonator and replaced it with one length of PVC pipe running straight down behind the fog light vent. You could really shove some air into your car if you ran it just behind the lower front vents and put some sort of medium in front of it to stop too many rocks or bugs from getting in. I will be doing a write-up on that soon to post here with 0-60 times before and after as well as fuel economy gains or losses. If I had easy access to a dyno then I would test that as well to really see what I am gaining, but I think 0-60 times will be enough to see if the car is making more power or not.
3. If it's speed you're after, then removing some weight from the car will definitely help. The spare tire is mighty heavy. The side steps are heavy as well but it looks like you don't have those. If you want to go extreme and don't ever use your 4WD, you could just remove your entire front drive system and replace your ECU with a junked 4X2 Pathfinder ECU.
Keep us up to date with your project and be sure to post some of your mods. There aren't too many of us on here who will judge you for anything you do to your car and those who will are usually mature enough to keep their fingers of the keys. Good luck with your projects!
