qship96 wrote:Wow, what the hell are you trying to say?
Only for those either unable to comprehend the owners manual, or too lazy to obtain one or read it?Q45tech wrote:Confusion sets in when you see this alternate [flash] between 2 codes and return to distance numeric.
I've never let my tank get that low. I wasn't aware that there was a message.ppastos wrote:ok but on my q45 when it says low washer/fuel it also starts to count. Like it would say 200 miles then 198, 197 so thats normal?
Welllll lets see now; About half the country is populated by Chicks? They own cars. Have you ever tried to discuss/show them anything about cars? Except operating the radio/audio of course.qship96 wrote:
Always shocks me how one can own anything as complex as a automobile and not have/read/understand the owners manual {same goes for audio components}
1.) Good. Always fill at ¼ tank level.Haitian_King wrote:1.) I've never let my tank get that low. I wasn't aware that there was a message.
2.) For the longest, my display gave me the stop lamp error. Turns out it was a bulb in the 3rd lamp. (There are two.)
Since the bulbs have been replaced, I'm thinking it could be a wire issue now.
You know what? I'm not sure if they were. Keith told me that it was a common problem and told me that that the problem was in the bulb wattages. He said that there were 3 bulbs of the same size but with different power draws and that's what could have been causing it. He had a large box with partitions for each bulb wattage. I don't know if they were Sylvania bulbs. I'll have to go look at mine.maxnix wrote:1.) Good. Always fill at ¼ tank level.
2.) Did you use OEM or Sylvania LL? If so, examine wiring and socket. If not, replace with such and discard non-specification bulbs.
1. There is nothing on a stock G50 that tells you whether the washer fluid is low or not.2. There is nothing on a stock G50 that tells you miles to empty.3. There is no "screen" on a stock G50, only indicators in the dash display that tell speed, coolant temp, fuel level, total miles traveled, and two trip odometers that allow miles traveled from zero for two trip functions, along with assorted warning symbols that illuminate when necessary.ppastos wrote:what do you mean weather dependent you arnt fooling with me are you
But at least you understand me I tried hard to explain it as easy as possible.
Actually, both our '92 & '95 show us a "LOW WASHER" message in place of the "B" trip odo reading when the fluid's low. The '92 has just started showing the "LOW FUEL" message with about 1.5-2.0 gallaons left in the tank. It never did with the first 3 or 4 fuel pumps (I guess the first one did, but that was before I owned it). The '95 has never shown the "LOW FUEL" message (for us), even though I ran it as low as I dared and it took 20 gallons. Maybe if I went further, but there's really no need.StarPD wrote:1. There is nothing on a stock G50 that tells you whether the washer fluid is low or not.2. There is nothing on a stock G50 that tells you miles to empty.3. There is no "screen" on a stock G50, only indicators in the dash display that tell speed, coolant temp, fuel level, total miles traveled, and two trip odometers that allow miles traveled from zero for two trip functions, along with assorted warning symbols that illuminate when necessary.
That's bizarre. Sorry, I never heard of this before.ppastos wrote:Ok but what I was trying to say was that when the low fuel/ washer is displayed right. the trip odometer starts going down like it says 274 miles (which is my current odometer reading) but then it goes down to 273 miles, 272 miles and so on so what I'm saying is that the odemeter counts down or goes down when the low fuel/washer is displayed. Any ideas?
You sure you have a Q?ppastos wrote:Ok but what I was trying to say was that when the low fuel/ washer is displayed right. the trip odometer starts going down like it says 274 miles (which is my current odometer reading) but then it goes down to 273 miles, 272 miles and so on so what I'm saying is that the odemeter counts down or goes down when the low fuel/washer is displayed. Any ideas?
I stand corrected regarding the "low W/S washer fluid" warning. Never let mine get low enough to have it illuminate, and failed to read the FSM cover to cover and memorize it. I stand by the rest of my comments, unless anyone can show me where I'm wrong. Please do.Q45tech wrote:Some Posts and counter posts just prove who is lying about reading and studying FSM or has a lower level of mental accuity or comprehension of printed English.
Page EL60 in FSM
Brake Pad Sensor?Q45tech wrote:Page EL60 in FSM
