More stress is definitely true since the centrifugal/centripedal forces acting on the rotating assembly is far greater than the power output around 10k rpms.Drift-wood wrote:I agree bluefire I think I realize the difference. Though I should have thought about it before I posted. The rb25 will reach and sustain 400+who and relibily stay there while the f22c may reach that number but will be seeing alot more stress.
Almost... ALMOST wishing I went LS instead of RB30. But the LS hype driving used engines up is so out of control its not even funny.AZhitman wrote:VH41DE won't get you anywhere near 350hp w/o boost. GL with engine management, and finding parts. Not a common engine, considering it was only used for 5 years.
Our RB is sitting around 260 with simple bolt-ons.
350whp in a S-chassis is a lot more than most people think, and few driver can make good use of that kind of power. Sounds good in a magazine, and bragging to buddies, but you'll spend more putting it to the ground than you ever did on the swap. Even sketchier with boost.
LS will do 350whp with headers and a cam. High-revving becomes irrelevant.
Thats great...but, where's the torque?flatrate wrote:my h22a honda makes much better power than my RB does
s14_sport wrote:Thats great...but, where's the torque?flatrate wrote:my h22a honda makes much better power than my RB does
flatrate wrote:s14_sport wrote:
My h22a made 440wtq and 610whp on 28psi... with a 6265 precision with pump and meth
Rb's are in the general area of this... they are by no means torque monsters... if you think that your a tard...
With a 30r my RB made 412whp and 330wtq on 20psi 92 pump
With a 30R on my h22a (same exact turbo used) i made 480whp and 376wtq on 17psi 92 pump
both have built engines... both using bone stock cylinders heads... (no cams porting valvetrain etc)
Im not trying to put down the RB motors... i love my RB and the music it makes...
RB's can make insane power, but it takes more work in cylinder head modifications etc which most poeple dont do ( i didnt) to make power with them
The last H22 motor i built for a friend put down 750whp and 570wtq on C16 TO4Z turbo ( BB 67mm) on 35psi... thats pretty nasty... show me an RB20 or 25 thats doing that...
again before people switch gears and call me names for going to bat for a honda... im just being realistic ive built and messed with both and so far my H has taken the cake
Also, what Lip is that on your kouki?
were talking less than a half a liter of a displacement advantage... more power under the curve is very minimal here... if your going for 600+whp on either engine "power under the curve" will suffer..Sil240 wrote:IMO the RB25 will be cheaper and make more USABLE power.
Power and torque under the curve.
Yeah your H22 head flows better than an RB20 & it makes more power but unless these are drag cars it doesn't really matter.
Since your H22 is FWD, getting that power to the ground is going to be fun.
