I'm not having any luck here so I am looking to you for some ideas and remedies. My RB25 has been acting up once it gets up to operating temp. Here's a link to the Youtube video of it idling.
http://www.youtube.com/watch?v=8rallMGZiQ4
Here's the writeup I wrote in the description section of the video:
"Troubleshooting what appears to be several things. First, it was running good all summer on the same tune. Raced a guy and the next morning the exhaust pulse sounded different.
No knock, good oil pressure, reloaded the tune, good battery, alternator and grounds everywhere, no change. Drove it more and now it cold starts fine but stalls on hot starts if it even starts in the first place.
So I replaced the IACV and that seems to have helped with the stalling after heating up, but I haven't redone the idle learning yet either so it idles artificially high. The Supra TT Denso fuel pump pulls 10.4A all day, so that seems about normal. I swapped out each LS2 coil pack and no change. I tested fuel pressure tonight (in video) and it is 35-37 psi which is low but increases with boost. I'm focusing on the fuel pressure regulator there as it probably needs to be upgraded to an adjustable unit.
The voltage dropping to 13.7V concerns me because it has never dropped below 14.0V for as long as I've had the car. And it is intermittant and only when the car is hot. After the video I restarted the car and the voltage was at 14.0 with both fans on. It might have dipped to 13.9V by the time I turned it off, but this just shows how inconsistent it is.
The fans each pull 15 amps, the fuel pump 10A, and coil packs 2A. The previous alternator was 1yr old and it also did the same thing as the one that is a week old. I doubt I got two failed alternators. Next I'll try to run separate battery voltage signal wires because I'm thinking the alternator isn't receiving accurate voltage readings so it knows when to bump up the voltage.
I'm really looking for help here guys. Any ideas are welcome...just don't say "it needs a grounding kit"
Sorry for the lengthy read, but I feel like I have tried everything and am at my wits end.
