LSDrift - I knew it was missing a cylinder by the sound of the exhaust and the lean AFRs so I pulled plug wires until one didn't change the idle tone. It was #4. Then I pulled the plugs to see if each was sparking. They were, so I knew it was fuel related. I switched the #4 injector with #3 (known to be good) and the problem changed to cylinder #3. I knew it was the fuel injector itself at that point. DW had me test the continuity across the injector pins and there was none. This means the internal coil is broken and unrepairable.
DW has been very helpful about this situation and is sending me a stock RB25 injector to use to get the car out of the garage one more time. I am installing a new LSD this week and I need to get it broken in before winter hits. Since I have a PFC, I will be able to scale that individual injector differently than the other 5 so it should run okay. I will NOT be creating ANY boost with this set up!
RRRB - I think I was just being oversensitive to the voltage. It was my efans turning on and off for the most part. I looked back at some early datalogs and it was exactly the same.
