300ZXttZMAN wrote:Great job so far keep up the good work, the frame rails are supposed to be like that you will need to section them together. The frame rails and core support don't separate from each other without cutting. My advice is to install the whole unit together and cut the rails in the same spot.
This was my initial plan until last night. Since my Z sits fairly low and the Ranger it hit sits fairly high, all of the damage was to the top of the rad support. The frame rails and lower rad support are completely untouched. Only the top part of the rad support, from the frame rails up, was smashed up all the way across (which is why the radiator and condenser were touching the clutch fan).
So anyway, I spent the last 2 days stripping everything else off the front (radiator, what was left of the headlights, etc.), drilling out spot welds, and cutting in some places. This is what I'm now left with, sorry for the crappy lighting:
The shock tower area and the piece of frame that stick out from where the fenders mount are also untouched, so I was able to fully remove the headlight buckets by just drilling out the spot welds and a little cutting to get around the wire harness. The annoying part is the the harness wraps completely around the outside of the engine bay, basically from one door all the way around to the other without a way to disconnect it so you have have no choice but to work around it.
My hope is that I can cut the replacement one the same way and sit in on whats left of the fender-support area, make my measurements and get it all lined up and then tack weld it in place. Either way it should be easier then trying to cut the frame rails and wheel well/shock tower area exactly the same way as the new one. Yes I will still have to do some small cutting to get the wire harness through and the various brackets that go on the sides, but I should be able to do it this way.
I also got the new support all striped down to bare bones:
As a side note, I was very impressed by how well some of the hardware held up in the front. Example, this bolt:
Yes, it did bend pretty bad but it didn't break! Quality hardware right there, especially considering it's only a little 10mm bolt. Made in Japan ftw!
