Holset is an absolute great turbo, will handle 45psi no problem. Durability, durability........ can't say enough about these turbo's. I ran one my Merkur XR made just a little over 300 to the wheels but had plenty of turbo left. There are plenty of guys running these on Ford 2.3 turbo. 400rwhp no problem. A little fabrication is required to make it work......down pipe and wastegate. Here is a picture of my old HY35. You can see down pipe need to be cut or welded and waste gate tube needs to be snipped and tapped into. If you are mechanically inclined, not a hard project at all with great rewards.osolorb wrote:i was thinking of upgrading my rb20 a little. has anybody ever put a holset turbo on the rb? i an thinking of this option instead of an rb25 turbo or any other turbo out there. i would like some input on the topic. thanx guys (and girls)
What are you basing this off of? HX35/HX40's are designed to push like 3 bar and don't even get really efficient until around 1.5 bar (22psi). Also, these things are known for thier great spool. My HX35/40 hybrid makes 1.5 bar by 3800rpm in 4th! I think that's pretty dang good when you consider it's probably making 500-500hp at that boost. I pretty much say WAY the opposite of everything you just said.Kansei240sx wrote:Make sure you find a small enough exhaust housing for these turbos or else you're in lag city.
These turbos run out of capacity around 15-20 psi depending on what model of HX/H1C/HY-30/35/40/ There is. Each model has several different compressors and exhaust housings that have different spool characteristics and compressor maps, with different surge lines.
Excuse the 40 part. I didnt mean to write the 40 on that list. the 40's compressor housing is considerably larger and flows much more air. Efeezi on a local forum here had a holset turbo H1C i believe or HX35 and was maxing the power to around 496 rwhp on 15 psi. Increasing boost yielded more tq, but only around 15 more rwhp. So its efficiency started to run slow. That WAS no a KA24DE though.Cjmartz2k wrote:
yes it will bolt up to the stock manifold. you need to clock the turbo to have it sit correctly.darkstar575 wrote:I just want to know if the hx35 will bolt up...I would love for it to clear the stock manifold...If it doesn't would you need a spacer? Would it also be a smart to use the internal wastegate or modify the manifold to allow an external wastegate?
HY's and HX's will make plenty of boost to 35psi in our little motors. Boost in my truck would keep climbing past 35psi. I have a Dodge turbo diesel and can attest to this, also had a turbo Ford with one as stated before and would pull really hard to 24psi. I know of a guy running a HX putting down 450 hp with rough tune.Kansei240sx wrote:Make sure you find a small enough exhaust housing for these turbos or else you're in lag city.
Why? It's one of the older ones, and the newer, more efficient HY/HX series are so easy and cheap to get.osolorb wrote:i think im going to buy the H1C holset for my rb20
Easy calculation for HP output is the CFM of the turbo, for every 1CFM =1HPtherefore if a turbo flow 600cfm it will be more or less 600hp.BoostsFed wrote:the hx35 is a great match up for the rb20/25. if you don't mind a bit more lag, the hx40 will scream on the top end. don't be fool, these turbo are head-to-head performance against the Garrett's GT series turbos. they are verrrrry durable, you all knew that, from diesel trucks. i'm going to bolt the hx40 to my rb25
btw! if i recall correctly the hx35 support around 600cfm which yields 300-400hp
Modified by BoostsFed at 8:21 PM 11/30/2007
This is not my car, I was just showing what potential this turbo has. HX35 won't be good for much more but then again, this is a 2.3l motor with a 2v head.BoostsFed wrote:i think the hx35 is choking your SVO; holding it back from real power. i think a HX50/55 will really lighten up that car.
what are you running on your rb26 setup??
gt42r is definately a good one for the rb26.i wanted to get that for my setup, but couldnt justify the cost of it; so the hx52 for the budget freak (me). my rb30 is in building phase, hopefully tuning by spring time.TurboSouthAfrican wrote:I have a GT42R on my RB26, doubt I will have to upgrade my turbo anytime soon. I would like to see some pics of your 30 motor, where are you located?
stick with the hx35 or hx40 and you will be fine. the hy series has a smaller turbine side vs the hx. the h1c or h2c are old, which being replaced by hx & hy series.osolorb wrote:what other hx, hy turbos can i use? what r the differences between hx , hic, h2c
