boker240 »
https://forums.nicoclub.com/boker240-u85310.html
Sun Mar 16, 2008 5:36 pm
ok buddy,,,u can use the jgs ,,,as im doin . u cannot use the hx35 w/ the ebay mani ,,i treid crazy *** into the brake mc.yes to the ic set also. i use one of those. the d pipe was the hard part,,, i v banded the down pipe at the turbo. welded one on the rear of the turbo and the front of the down pipe.the best connection ive had yet and this is the 3rd setup ive had. the rest of the d pipe is custom also ,,,had to mock it up weld ,and mock it up again and weld to get it right.i just cut like 3 peices of pipe to fit from d/pipe to down pipe and duct taped it together ,,brought it to work and welded it up.
