holset hy35 and rb20det
diosr20
hello i have a rb20det and i am considering bolting on a hy35 from a 01 diesel turbo ive heard but dont know for sure that this will bolt up it is a standerd t3 flange right? to go with this turbo i want to use 440cc injectors im only looking for around 350 with decent spollup and good midrange power i have a old school hks fcon controling fuel right now will this be able to keep up and will my stock rb20 maf keep up?
Original Poster wrote:
Hello,
I have an RB20DET and I am considering bolting on an HY35 from an 01 turbo diesel. I've heard, but dont know for sure, that this will bolt up. It is a standerd t3 flange, right? To go with this turbo, I want to use 440cc injectors. I'm only looking for around 350hp with decent spool-up and good midrange power. I have an old school HKS FCon controling fuel right now. Will this be able to keep up, and will my stock rb20 maf keep up?
Edited by Moderator:Please make an effort to use punctuation and grammar. It makes things so much easier to read.
midnightsliding
im like 99% sure that its a t3 flange i was wanting to go this route a while back on my Rb25 but not im trying to reuse my old turbo with new Tial wastegate and manifold hope its better if not i was to get a holset also. vary good turbo for the price.
diosr20
i hear it spools at around 3200 on ka's i think its a .48 but im not sure
Dragon76
Car: too many
it is a T3 flange . I have a Hy35W setting in the garage that i tested fitted on my Rb20 it was a no go with the stock manifold the Compressor housing hits the manifold not allowing you to bolt it down . you would need some spacer of some type or get a top mount manifold .
diosr20
what about clocking it? is there a different holset turbo that might fit?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Why don't you just buy another T3 flange and either weld or bolt it on.
Would that be enought space for the compressor housing??
mello88
Car: s13
Do you have a compressor map for the HY35? I found one for the HX but I'm not sure of the differences. The HX looked like a decent map for a 10/12/14psi 2.0L, what kind of boost were thinking of running?
Shahee1
Car: 1993 240sx w RB20DET
The HY35 will fit ... but you will need a spacer I had to do the same for my rhc6 ... The compressor housing touches the manifold and will not install flush.
Bwana
Car: Denali
HY's have a slightly smaller compressor housing than the HX. HY's were used on auto equipped Dodge cummins trucks while the HX was used on manual trans trucks. They're both decent turbos, and very reasonably priced.
pirate87
Car: 1997 Nissan 240sx SE
to re-hash an old thread....
any thoughts on the HY35 on an RB25? Would the compressor housing be too small?
Cjmartz2k
Car: Hunting for a '89 GTR now
Yeah, I'm wondering also, but a HX35 on a RB25 in my case. If somebody can point me at a site, I'll look all this up myself. I've got a brand new one in trade for my T04e P trim which I am outflowing at the moment.
pirate87
wait wait, you're out flowing a TO4E P trim? maybe I'm not understanding you correctly but I have a TO4E O trim and I dont make boost til about 6000 rpm...
Cjmartz2k
Something sounds wrong with yours then. I'm fully spooled by 5k'ish (1.3) then the boost slowly starts cruising back down to .9 bar. This is on a RB25 as stated above not a RB20 if your thinking that.
Shahee1
Here is a god site for HX35/HY35/T04E ... I'm about to run an S258 Borg Warner ... The HX35 was awesome and I have seen a few HY35 in person put up nice numbers ...
http://www.timsturbos.com/index.html
CoupedUp
Car: 1993 Coupe
HX35 is a good sized T3 turbo and the exhaust housing it comes with is NOT a .48 A/R!!! It is more like a 1.0* A/R. You can find downgraded exhaust housings. Do some research. .
OpeLok
pirate87 wrote:wait wait, you're out flowing a TO4E P trim? maybe I'm not understanding you correctly but I have a TO4E O trim and I dont make boost til about 6000 rpm...
what the hell? I have T04E p trim on my rb20. I boost at 4k rpm all day long. Get some tuning or something. I only have street tune with EBC
just to clarify I also have .60 compressor, and .69 a/r exhaust
pirate87
OpeLok wrote:just to clarify I also have .60 compressor, and .69 a/r exhaust
yeah..... mines a .84 A/R turbine on an RB25, we spent 10 hours dyno tuning it on a power fc and thats that
the p trim should have a .84 exhuast too, just with a large exducer on the turbin, btw
Modified by pirate87 at 1:37 PM 6/22/2007
OpeLok
odd... I bought mine brand new from AZ garrett distributor. That's what he told me it was "p trim"
SeVa-S13
Car: '05 GTO 6spd
Please start whoring pics of your engine bays/dyno charts...both of ya
OpeLok
SeVa-S13 wrote:Please start whoring pics of your engine bays/dyno charts...both of ya
in process of doing intake manifold. This is how it sits now. I'm takin my sweet *** time. It is no longer my DD.
this is from way back(different angle)
pirate87
OpeLok wrote:odd... I bought mine brand new from AZ garrett distributor. That's what he told me it was "p trim"
could be different between brands...idk. the turbo you have mounted in the pics looks much smaller than mine.
I wish I did have a pic of my dyno chart, but after 10 hours of tuning, getting a printout was one of the last things I was concerned with. Bottom line, once the thing spooled ( about 6k) the HP graph took off...
Bottom bottom line, Im trying to find a good holset HY35 for better spool.
Here are my whore pics:
Cjmartz2k
I've got a bottom mount, so there isn't much to see, but I'll take a pic tomorrow. On a side note, I got spanked hard by a stock turbined (running 1.4 bar), heavily bolted on Evo III last night, so I really need to find out what this thing will do on my motor. I need another 100hp and some sticky tires to spank him the way I want to.
Cjmartz2k
O yeah, forgot to mention. It's a HX35w with a 18cm? exhaust housing. Quicker spool would be nice, but bigger top end is what I'm after. I'm going to have to drop/modify my front K member to make this thing fit, so I want it to be worth it.
OpeLok
Quote »I wish I did have a pic of my dyno chart, but after 10 hours of tuning, getting a printout was one of the last things I was concerned with. Bottom line, once the thing spooled ( about 6k) the HP graph took off...[/quote]what did you end up putting down though, and what other supporting mods do you have?
Here is a pic of my t4 next to the stocker
Cjmartz2k
Okay, I went to the dyno today. 399.5rwhp. It was hot and muggy as hell, but I'm happy with it.
Now back to the Holsets!!
pirate87
nice numbers man!
OpeLok wrote:what did you end up putting down though, and what other supporting mods do you have?
I ended up putting down 300 rwhp on 10 psi of boost out of the TO4E
my supporting mods are: Top mount manifold, Greddy Intake manifold, Q45 Throttle Body, Z32 MAF, FMIC with 3'' piping, tuned on a Power FC with FC datalogit....I think thats all...
Bwana
Car: Denali
FYI guys there are exhaust housings available for the hx down to 12 cm iirc.
Cjmartz2k
pirate87
what worries me though is the HX35 compressor clearing my valve cover (why I'm leaning towards the Hy35), right now on my TO4E both the comp and turb have about 2-3 mm of clearance mounted on my top mount manifold.
Cjmartz2k
They both have the same compressor, just different exhuast sides, so I don't think that'll help you.
