OK here is the low down on my holset experience. It spools great in 3rd and 4th, about 300rpm slower then my GT2871R according to the dyno plot. It makes 400whp at 23-24psi with a cheap ebay log mani and a 2.5" DP and the stock cummins turbine housing. It is to hard to launch in first without a 2 step or a 35 shot to get it going but it pulls like a train in 3rd and 4th and traps 95-96 in the 1/8th. I could cut consistant 1.6-1.7 60' with the GT2871R but it was flat on the big end of the track and the HX35 setup is just the opposite. I can't launch it consistantly for s*** put it makes good power. For the Holset on the SR20 i would go with the HY35 for anything less than 450whp because it will spool much faster or I'd do the HX35/HX40 with a BEP .70 ar non divided turbine housing and solid lash adjusters and let it rev to 9500rpm.
I am selling my HX35 and buying a BW S256 .55ar from extremepsi and going for a happy medium between the 2871R and the HX35. I can't get the .55ar housing for the HX35 and I want more response and 20psi before 4000rpm. I'm getting 20psi in 4th at about 4400rpm with the HX35.
IMHO the HX35 and anything larger than a GT30R are more suited for the KA-T with more displacement or a SR with solid lifters that revs to 9K+rpm. The HY35 will make about 50 more whp than the GT2871R and spool just as fast with the 9cm2 housing. I sold my HX35 for $400(more than I have in it), and I'm buying this......
https://www.extremepsi.com/sto...age=1
It is just to good of a deal to pass up. It should spool about like the GT2871R and be capable of 25-28psi with the .55ar BEP housing. Here is the housing...
http://www.timsturbos.com/SSTu....html
