idahotuner wrote:
the gold nipple is where the line for the waste gate should come from.
tatertuner, thanx for the help, but I do understand how a WG works. I used the brass nipple that you pointed out for my pressure source and it was over boosting like crazy and the gate wouldn't open. When I got home today I removed the nipple to see what was up and apparently the truck it came off of was running 35-40psi because this is what it had feeding the stock internal WG actuator... I replaced it with a regular 1/4" nipple and the gate opened around 11-12psi. I am currently running 15psi with this setup... My afr is in the 10.4 range with the greater mass of air from the larger turbo going through my cobra MAF. I will be installing the intake and raising the boost until I run out of fuel on 110 race gas within the next week. The HX35 at 15psi would be very close to my GT2871R at 21psi if it wasn't running so fat. I could lean it out with my SAFC-2 but I think I'll just raise the boost!!!
