Hogg wrote:Done ready to get machined,
Anyone who has any tips on that stuff those would be very much appreciated as I am a total noob to the machining scene
ok....get this :
1- new oil pump <--check some UK/JAP fourm's to see if there is a moded oil pump to increase oil in the engine.
2- brand new water pump : againe check as above.
3- new timing chanes x2
4 - i don't know how much the stock rods/pistons can handel...so if i where you go forged.
5- new sensor's...replace ALL the sensor espciely (SP?) the knock sensor.
6- check the heads for crack's/wrap etc. replace if nesserey.
7- check valves and guid's seats etc etc....same as above.
8- valves springs-retienrs- etc etc...as above.
9- check the block for crack's...if there is repalce.
10- check / RE balanc the crank.
then order some FULL gasket set and replace them ALL....
and one last thing..if you want CHEAP engine parts...ask any of your friends to go to U.A.E junk yard in al-sharriqah....there is a LOT of JDM junk car there...
Hope This Help
Regards,
Ali
