Yeah, so do you, ya fruit budder, yet your car warms up 100x faster than mine.asoomal wrote:You live in Canada
OMG, why didn't I think of that?!?!?asoomal wrote:Try hitting the limiter for five minutes.
I've never changed the thermostat. And for the clutch fan. . . I may have to get back to you on that one. I'm pretty sure it might be the thermostat. . . Hmm or maybe not.FlatBlackIan wrote:When was the last time you changed the thermostat? If its stuck open, its not slowing cold coolant down to help the engine warm faster.
How is you fan clutch. If the clutch is seized the fan is spinning at full RPM all the time, pulling all warm up heat out of the radiator.
yah, id flush and put a new t-stat... get a nissan oe t-stat or nismo, the will work for shure...Jagstang wrote:
i started laughing my a** of when i read thisasoomal wrote:Try hitting the limiter for five minutes.
I think you're backward. A high temp stat opens at a higher temperature, meaning the car runs hotter. Colder thermostats open at a lower temperature causing the engine to run cooler. Hence why nismo is colder than oe and mishimoto is even colder than nismo.SirSilvia wrote:
Right now, I'm running a high temp stat i use for the summer time and should probably switch to a low temp one to make it heat up faster.
I used an OEM thermostat. It's weird after installing it, and idling the car, it seemed slow. But just a few minutes ago, I went to test drive it and the car got to the middle of the temp gauge within 3 minutes and kept going up.PyR0NiAk wrote:What thermostat did you use?
Hey hey, the roads here vary. It depends where you will be moving exactly. But overall, the roads are above average here.hilux30 wrote:you have air in the system, that will cause a fast spike in the temp. so must fix that bleeder.Hay since you from BC, I might be moving to that area of Canada (job) and I'm not sure if I should take my S13, how are the roads there?
