hks cast exhaust manifold fitment
Carl H
for those of you curious to know if the above mentioned manifold fits into the car with space you will be glad to hear it does.i just dropped my rb20 into my s14 using the r32 xmember and fitment is great.there is space for the downpipe and for the wastegate, however the wastegate comes close to some of the brake linesthe turbo outlet clears the steering shaft by an inch or so, so no worries there.i will get some pics up soon of the fitment as im sure you guys are curious to know how it fits.also i do have quite a sizable turbo on the manifold
krayton
cool stuff. good to hear.
post pics when u can!
Imissmyturbo
Car: Car's, Turbo's, sking
I have on for my RB25 in an S13 using the R33 crossmember. I hope I don't run into any issues.
krayton
Imissmyturbo wrote:I have on for my RB25 in an S13 using the R33 crossmember. I hope I don't run into any issues.
is it already on? did you re-drill for a t3/t4 (iirc its for a t4 flange)
let me know, id be interested if all went well, and you used your t3/t4 still
Carl H
the manifold comes from hks drilled and tapped for a t3 but it can support a t4 turbo if you drill new holes.
DETurbine
Car: Nissan S13 RB25
How much did you guys pick these up for and what was the cost on them?
I would like to see someone fit a large turbo on the manifold and see if there are any clearance issues with the steering shaft or any of the brake lines.
Imissmyturbo
Mine is taped for a T3. I know accel junky wasn't able to fit his S cover T04 compressor with the HKS manifold. I have a T04E cover and it should fit.
Carl H
speaking of accel junky (daniel) i actualy bought my manifold from him.ive a gt30r mounted to the engine/manifold and while it is a tight fit there is clearance all around.the brake lines come very close to the wastegate, but then again i have a z32 master where as the stock s14 ones should be fine.as far as the steering shaft, the outlet comes close but there is room around it.
krayton
any updates with pics?
ill be at this stage soon, so just curious
Carl H
ive a few pics but they are pretty crappy.need to take new ones with better lighting and a good camera mine is teh suck.i will try and post some up tommorow evening as well as pics of my swap.
Carl H
some pics as promised of the manifold and fitment.
Carl H
another
Carl H
yet another
Cornloaf
Car: 1990 240sx
carl - you have an RB20 right?? i was planning on going with GT30R with that same manifold, i wasnt sure if it would clear. Are you using McKinney mounts?? Also, make sure to post somedyno numbers once you get evrything all tuned in.
BoostFab
Car: S13cp, S13fb, S14z
carl is that blood or oil on your floor...
krayton
thanks for the pics.
on this topic, anyone know if a t3/t4 will fit ok on the hks manifold???
Carl H
cornloaf - yeah its an rb20 and yes that is a gt30r on the side of it. and no mount kit is being used with the engine, just the r32 xmember.boostfed - thats a pan of ps fluid, i think ;Pkrayton - its a gt30r on that manfiold which is slightly larger than most t3/t4's ive seen. i would imagine that the to4 b and e housings would fit fine not sure about the s.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Carl H wrote:some pics as promised of the manifold and fitment.
looks like your going to have to put a bolt in that bottom stud to get the down pipe on. or cut it a lil shorter.
WDRacing
Good manifold, I ran the same one on my Skyline. Cept I ran a TO4 and had the flange ported. I had to take my motor mount to a bench grinder and shave off the corner to make the turbo fit. I hate bottom mount manifolds.
240Z_Master
Car: 1971 Datsun 240Z
If anyone has one of these manifolds laying around as an extra, I really would like to run one.
modestmouse
I have one laying around. I haven't decided if I'm going to use it yet or not so if you'd like, you can make an offer. [email protected]
tight240
I would also be interested in the manifold, how much did you pay for it?
eh?
muuu
Modified by eh? at 11:14 PM 12/1/2005
Carl H
eh? wrote:I have a 40mm HKS wastegate for sale to fit that manifold. They're hard to find and expensive..
no sh1t, i paid 370 for my gate cuz i couldnt find one for sale on any forum and there was no way in hell i was going to buy a copygate.
eh?
And it sucks for me because the base plate flange needed to weld to another manifold is around $60-$70. I'd rather sell this and get a 38mm Tial.
240Z_Master
Can't you use one of the bigger TIAL wastegates?
modestmouse
tight240 wrote:I would also be interested in the manifold, how much did you pay for it?
Sorry, I sold it to a member of the board yesterday. Quick huh?
tight240
Dag!!!!!!! So where did you get it from and how much did it cost?
240Z_Master
How much do you want for it?
eh?
meh, I just bought the flange for it :/. No longer for sale.
