I H8 UR DSM wrote:why 264's ??
drumma022 wrote:As far as 10s I'd say that is correct for you to be the first that i have seen hit the 10 mark, however many are capable motor wise, but limited in traction. I have seen 126-130 mph trap speeds from an SR post, but with crappy traction off the line... I just love the FD and i love the SR. That is just plain awesome if you ask me.
240Z TwinTurbo wrote:The car ran in Orlando several weeks back, but had some problems that were since resolved. Here is a link to pics:http://www.eng.fsu.edu/~jthagard/upgrade/
The catch does get a fair amount of oil in it from blowby. Once a filter is placed on the turbo the catch can will be hooked to the turbo inlet and the catch can filter blocked. What this does is to create a vacuum on the block under boost.
As far as the gains, the 2 graphs before and after are about the same until boost hits and they then seperate. Will post the graphs later.
240Z TwinTurbo wrote:Couldn't get the 272 cams in time for our race. We will upgrade when the race motor is built. As far as Enjuku, I don't know what they have done and if they have made more power then that is great. I will say this, I have yet to see and SR20DET in the US run into the 10's, but a lot of claims of 400+++hp. Maybe I am wrong???
pampadori wrote:How much is a fair amount? say, one trip down the 1/8th. about 1/4 of a qt?
where does the block tube that went to the valvecover tee go now? i see it chillin back there in the pic. i'm having trouble with oil filling up my catch can every so often. can you help me out with this?shaun
Siddhartha wrote:I'm assuming by "staying away from the wall" you mean they're having traction problems . . .
I'm confused . . .
pampadori wrote:your catch can explanation makes since somewhat. but do you have a pic of your setup? here is how mine is set up. i might put a drain on the bottom like you said. i'm tired of having to empty it out every week.with the other end of my catch can going to the intake, my turbo and intercooler would get oil coated. also, the vaccum would only draw out more oil.shaun
GodzillaFan wrote:umm.. pressure/vaccum in the block (oil pan, timing chain, rocker arm area) should not affect how the motor revs at all. the pistons arent working "against" it because when 2 of your pistons are pushing down, 2 of them are going up....the turbo stangs probably use the vaccum pump to clear out the massive amount of blowby... as it can contaminate oil in a hurry
