HKS Cams Dyno results
Phax
Car: Control dynamics
240Z TwinTurbo wrote:Don't be an idiot. According to your theory we should just seal the block because pressure buildup in the block doesn't matter since 2 pistons up....2 pistons down evens out the pressure. Oh, so with a vacuum pump the blowby cannot contaminate the oil??? Blowby contaminates the oil whether you evacuate the block or not. It all the little things that you can do that add up to make a better running engine. I am just trying to provide those who have a clue some ideas and assistance.
We appreciate it. :D
I H8 UR DSM
Can you send me some pictures of your Z, seems impressive, those cars are awesome : )
[email protected]
Jesse
I H8 UR DSM
Did you mention what engine management your running?
240Z TwinTurbo
Car: 2006 EVO IX, 1991 NSX
Sorry, been out of town. I run the Electromotive Tech II fuel management. Here is a main pics folder:http://www.eng.fsu.edu/~jthagard/3liter/pics/
I H8 UR DSM
that car is great : )
Nathan
What is that turbo if you dont mind me asking?
sultan
on his site it says "Twin Mitsubishi TDO5 16G's w/ 7cm housings" and on hybridz.org he said he plans to upgrade to 20G's later on. that's for the Z, not the RX7
BuudWeizErr
BuudWeizErr wrote:That's not the best pic, but dare I ask, where is the wastegate?
Nathan
thanks sultan...somehow I was too much of a tool to see his website
pampadori
Car: 91 Nissan 240SX coupe
well here is another question...at idle, i have pressure coming out of the vent. not vaccum like other cars i've noticed. what is the deal here. what should i have??? i do have cams so my vac on my pcv isn't as strong as stock (12in/hg instead of 20in/hg)shaun
GraySilvia
Car: auto-x, drag racing, beer
I think the wastegate is mounted right before the turbine inlet, you can BARELY see it if you look close, it's a dark pic.
240Z TwinTurbo
pampadori wrote:well here is another question...at idle, i have pressure coming out of the vent. not vaccum like other cars i've noticed. what is the deal here. what should i have??? i do have cams so my vac on my pcv isn't as strong as stock (12in/hg instead of 20in/hg)shaun
You can clearly see the wastegate in this picture:
I assume your PCV is hooked up to your intake manifold. This should help to evacuate the block while off boost. I do not think it is that critical at idle or for off-boost situations. However, under boost it is more important. In addition to freeing up some revs, it will also help to better seat/seal your rings. The turbo on the RX7 is a 62-1(P-trim .58 a/r)
