IanS »
https://forums.nicoclub.com/ians-u23642.html
Mon Oct 15, 2007 7:08 pm
if you want more boost, you will need to adjust it tighter, I have mine adjusted to 11 PSI and I have to pull super hard to get it on to the wastegate arm, if you cant get it on with just your hands, you can use an air nozzle attached to the wastegate line to force it to open, then slip it on.
