-Stock Long Block-Stock Ignition and Coils-Stock Injectors-Stock MAFS-Stock T28 @ 13 PSI-Megan Manifold-Elbow Back Exhaust-FMIC(21"x9"x2.5" Core, 2" Hot Pipe and 2.75" Cold Pipe)-Fidanza Flywheel
Why don't you guys throw some guestimates out there and give me a feel for the power I should make.
I understand this has been asked quite few times, but given the numbers I got out of my last dyno pull on a post MAF pre-turbo intake leak and inability to rev past 3500 RPM. I think most peoples SR "Standards" will be out the window. This is speculation anyhow.
EDIT: DYNO'D!
I dyno'd this past weekend, made 272.3 WHP @ 13 PSI on a Dynapack 4000 Chassis Dyno. Which is roughly 294 WHP on a Dynojet.
It was at 10.3 AFRs at the beginning of Full Boost notice the torque dip. It then leaned out to 11.4 AFRs and slowly started to lean out to 12.2-12.3 at the end of the pull.
Thanks for looking.
With a tune I know I could hold that torque steady at the beginning of full boost and make over 300 WHP.
Modified by CoupedUp at 12:56 PM 4/6/2008
Modified by CoupedUp at 12:57 PM 4/6/2008 EDIT: DYNO
Modified by CoupedUp at 12:59 PM 4/6/2008
