Thank you Dennis.. The IAC is adjusted IN all the way right now to maintain it... Seems to be no difference.. I also changed IACs with one that should be perfectly clean.....Q45tech wrote:Remember to disconnect the IAC connector that way the base idle can be set without ecu adding air [opening IAC [10-15%]]...........just the IAC screw air bypass and under throttle plate supplying air [what those tiny notches in botom of TB do.
Then ecu adjust injector opening time and ignition advance to maintain 550-600, then IAC [reconnected] adds 10-15% =~~650-700.
Think about how important the IAC balance point is, it must be just right to raise or LOWER idle.
Same with base ignition advance [15 degrees hot with timing light]....the ecu assumes it is absolutely correct as otherwise everything will be offset in real terms.
Have you tried replacing ecu, as I remember Freds was funky [or am I confused with what car you are driving]?
I always look [with Consult] at MAF voltage to make sure it is close for conditions to find air leaks or MAF problems [ 0.1 or 0.2 volts error is about all the ecu can tolerate.
Lots easier to swap the coolant sensor if you remove the temp gauge sensor first.elwesso wrote:Next im gonna try the coolant sensor... Ill buy a new one, but I cant find a socket to go on it.. It has to be deeper than normal, but not a true deep socket.....
Dennis, im starting to think that someone bypassed this or something... Last night as I was piddling with it, i left the IAC unhooked... When I started the car it idled at about 800.. Then when I went to leave school, i started it up and it did the same thing... then i reattached the IAC and it went up to 1200 like its supposed to... Im starting to think something is goofy with the TB...Q45tech wrote:How are you measuring rpm, can't trust the tach at the bottom end of range.........what you think around 700-800 may be 100 rpms off.
The TPS must stay [be set] between 0.4 and 0.5 volts as read by ecu not the VOM method with coolant at 176F [170-185F]..........this is with oem air box/filter not dreaded KN cone or other junk.
What is idle vacuum [hate that word] as measured by teeing to FPR vacuum port ~~18" HG what is MAF voltage............couple of degrees in timing 14-16 is all that is allowed.........sure the throttle cable at TB is loose eough .....1/4" downward pressure before rpm change.
Did someone bypass the coolant lines to TB [hot wax warmup system]?
Hm.. So the car idled fine without the IAC on? Did you try driving it that way?elwesso wrote:Dennis, im starting to think that someone bypassed this or something... Last night as I was piddling with it, i left the IAC unhooked... When I started the car it idled at about 800.. Then when I went to leave school, i started it up and it did the same thing... then i reattached the IAC and it went up to 1200 like its supposed to... Im starting to think something is goofy with the TB...
Bah.. Who needs those electronic gismos anywaysQ45tech wrote:Stange how people want to disconnect components when they won't take the time to figure out what's wrong.
Hm... I'm looking at my plenum right now. And it appears that where the physical IAC sits, it does not enter the plenum. It has a hose coming into it from the intake, and a hose going out of it to near the TB. That''s it.Q451990 wrote: and if you get any overlap squiriting into the passages in the plenum or valve, that could be a problem.
Heath
I dont care about the labor... It keeps me off of NICO for a few minutes.DAEDALUS wrote:Does the car not have a fast idle cam? I didn't see it mentioned. You can just visually check if the coolant hoses are bypassed on the TB. Keep an eye on the IAC voltage while the idle's fluctuating. Still trying to stress that swapping parts is usually not the way to go about figuring out what's wrong. At least you're not paying dealership retail on the parts, but the labor (your labor) is always there. You can always backprobe voltages at the ECU, even for the TPS.
Actually I forgot to plug it back in... I had it unplugged when I was trying to set, and I went to eat diner... never made it back out to the Q.....Q45tech wrote:Other than maintaining idle [what the zero to 80% duty cycle does] under various auxillary load changes [AC, PS load, [voltage -alternator demand for HP]...............the IAC acts as a "dashpot",when you suddenly let off throttle at speed to avoid the engine dying with throttle closed.......steps down rpm as speed decreases....CRITICAL function.
"Fast idle cam" is really a hot wax controlled spring/plunger heated by coolant in TB.
It has passages that flow directly into the plenum... The hose(s) feed the valve.PoorManQ45 wrote:Hm... I'm looking at my plenum right now. And it appears that where the physical IAC sits, it does not enter the plenum. It has a hose coming into it from the intake, and a hose going out of it to near the TB. That''s it.
But I understand what you mean about the RTV being harder to work with. It'd be very tricky to not have any pinch into the passage way
Chris, thanks!!!s13sr20chris wrote:i dont mess with the q's too much but i have to think this is one of those situations where you just work backwards. 1. the only issue is the idle right? and maybe some fuel consumption issues2. so it idles high but with iac is ok.3. the base idle/ign timing is correct.4. for some reason the iac is working overtime.5. not iac as it was checked with known good.6. i dont have an fsm with me is the q iac a stepper motor or pulse-width activated type?7. the ecm(or possible harness fault) is commanding extra rpms/air(this assumes its not a vac leak)8. does the ecm think there is a load(p/s switch, a/c switch, etc.)is the ecm in failsafe for some other component?
sorry for all the questions and going over stuff you guys have already been over. im am just trying to get in on the action.
